Hello everyone,
I've been lurking around this forum for a while now and thought it might nice to say hello to everyone. Thanks to all for sharing your experiences and knowledge, it's such a pleasure to read all the posts from @MAVA, @steveb, @quakercity, @Merc-S600 and so many others. Hope to contribute a bit in the future as well.
I recently got my hands on a 1999 CL600 with 152k miles. It's been really well maintained and driven by the same person for a long time.
This car is so silent and effortless, it's such a pleasure to drive. In the past I had a few W124 diesel wagons, but this one is just at a different level. I quite enjoy how quiet it is even at 70-80mph. My spouse did not want to get out of the car on the first trip, as she really enjoyed and appreciated the craftsmanship. It's been my dream for 15+ years to own an 140, and I am really grateful that I could do it now.
While overall the car is in really good shape and everything works (the only thing that does not work is the parking sensor light on the driver side), there are a few things that are needed.
Since I got it 300 miles ago, apart from driving it, I also changed a few things:
- cabin air filter, together with the recirculating air filter. I replaced it with a proper MB charcoal activated one. This helped a lot, as if I was leaving the car for 2-3 minutes to idle with the door and windows closed, I could smell some gasoline. That's now gone! The recirculating air filter inside the dashboard was really filthy.
- changed the spark plugs with Bosch F8DC4; I got the ones made in India from FCPEuro. Did a 20 minute drive test and they seem ok. The ones before also looked ok, but they were the FR8DC+, which are the resistor type. The car before shaked a bit at idle and the RPM would kinda oscillate a bit. The manual calls for F9DC0, which from reading all over the forum seems that it should be replaced with F8DC4. Will see how things go. Also found a bit of oil on the thread of one spark plug, but the electrode tip was fully dry. I assume the valve cover is seeping oil on this cylinder.
Unfortunately, one of the coil boots was damaged a bit (from cyl 12), so I need to order a new one. Found an NGK for $16 or the original one for $72 at FCPEuro. Haven't decided yet which one to order, I am inclining to go for the original one to keep them all the same.
Next, I plan to:
If you got so far, thanks for reading. I have a few questions around an oil change and the motor mounts. For the mounts, I got these genuine MB parts a few days ago:
140-240-02-17 -- for the right one
140-240-15-17 -- for the left one
2122400418 -- for the transmission mount.
Is the transmission mount part correct?
Regarding an oil change, in the past few years the service used Motul 8100 Xcess 5W-40, together with some additives. I was thinking of changing the oil to Pennzoil Platinum Euro 5W-40 - has anyone used Pennzoil in their M120? Do you usually add additives?
Should I just keep using Motul 8100 Xcess?
Thanks again for reading and looking forward to slowly meeting and engaging with other members.
Cheers and happy motoring!
- engine mounts
- some vibration around 45-60 mph, after that it's gone
- new tires
- apparently the valve covers are seeping. From the huge service record folder I have, I found that these were done around 10 years ago. It costed over $4k even at that time, so I might have to do it again.
Next, I plan to:
- change the differential oil as who knows when was that last time changed. I got some 85W90 Hypoid oil from Liquid Moil as per the manual.
- change the air filter (forgot to do it today when doing the spark plugs). I got the MANN C3484.
- inspect visually the flex disk and the drive shaft
- I would also like to change the motor mounts, but I am still on the edge if I'll do it myself or not. Got quoted $640 for a shop to do it (with my own parts , which means no warranty on the work). I read all the forums posts around changing the mounts on M120, so much great information there, thank you.
- some front suspension work is needed, which I'll probably go somewhere to do it as I don't want to mess with that.
- the left headlight (factory Xenon) is not adjusting horizontally. I need to study that one and take it apart to see if I can fix it. I can adjust it up and down just fine.
