After Searching for the BAS/ESP, ABS intermittent dash board lights I came to the conclusion that I might want to replace my Brake Light Switch p/n 0015450109 for $21.10 at autohausaz.com
So I tried a Search for the location of the 129 Brake Light Switch and was unable to find it. ***Please Help me with it's location*** so that I can either install it or get it installed. Location pictures would be nice.
After the R&R I understand that it's smart to synchronize the ESP by turning the wheels Lock to Lock.
If replacing the Brake Light Switch doesn't turn off the BAS/ESP, ABS lights then:
1) Check all tire air pressure.
2) Check that you have correct front to back tire size.
3) Clean ABS and wheel Speed Sensors.
4) Alternator Voltage Regulator Brushes and R&R of 119 alternator and R&R of 113 alternator.
5) Replace battery.
Thanks for your help in advance!
5) Replace battery.
