» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W124 E,CE,D,TD Class
Closed Thread
Old 01-09-2009, 09:17 PM   #1 (permalink)
Rarität!
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 TD + (Audi/VW)
124 DIY Thread
Alright folks, this still needs to be populated with information, so please PM me or add your suggestions to the DIY discussion thread (see below VV).
124 DIY Topics
Open DIY discussion thread
Info
New members are highly advised to fill out their profiles before posting questions. Your profile should include the vehicle you drive, where you live and the total number of miles on the chassis. This helps other members to better render assistance in a timely manner.
124 specs FAQ
124 Buyers Guide
Great thread with shots of early 124 development
Transmission schematics
FYI - Rare 124 spring perch failure
Cleaning the front windscreen
Cost of ownership
Online W124 Service/Shop Manual
Online manual with index
Official Mercedes browser-based subscription EPC (free for one year)
VIN decoder
Brakes
Brake Pad Replacement
Replacing Rotors and Pads
Electrical
Blower motor
M104 wiring harness and ETA
Step-by-step KLIMA test procedures
Accessing the cruise control amplifier
Blower Motor Replacement
Overhaul of the windshield wiper mechanism
Wiper Motor Lubrication
Power seat switch repair
Hirschmann antenna fix
Fixing a jumpy fuel gauge
Engine/Transmission
FYI - Cam wear on early M103
Fuel mixture adjustment
Servicing the steering pump filter
Replacing Power Steering Filter
M104 Wiring Harness
Rewiring M104 ETA
Cleaning Throttle Body on M104
M103 Timing Cover Reseal
How to Turn Torque Converter During ATF Fluid Flush
M119 Replacing Oil Guides
M119 Distributor Cap and Rotor Replacement
Diesel afterglow tips
Thread with links to 4-Matic transfer case rebuild info
EGR cleaning video
Exterior
How to remove mirror covers
Front Fender Removal
HID Projector Retrofit
Replacing wagon hatch struts
Soft top operation for Cabriolets
Interior
Upgrading seats/seat heaters
Cleaning Seat Switch
Repairing a binding seat tilt mechanism
Replacing/upgrading cluster lights
LEDs for cluster lights
Removing inner door panel
Repairing Busted Odometer
Make Your Own Instrument Cluster Removal Tools
Removing floormat backing foam
Removing dash vents
Replacing the steering wheel contact ring
Passenger airbag retrofit
Suspension/chassis
Awesome thread with pics showing full suspension rebuild
Ball Joint & Tie Rod Replacement
Rear Wheel Bearing Replacement
Rear suspension outer carrier link bushing replacement
Zeitgeist is offline
Closed Thread
124 Sedan Picture Thread salamanca W124 E,CE,D,TD Class 1003 Yesterday 09:39 AM
Do It Yourself (DIY) repair thread and wheel and tyre thread Dr.Grillz W126 S,SE,SEC,SEL,SD,SDL Class 112 10-27-2009 07:02 PM
124 Performance Thread mcbear W124 E,CE,D,TD Class 151 10-24-2009 05:42 PM
124 Picture Thread Zeitgeist W124 E,CE,D,TD Class 0 12-14-2008 01:20 PM
Thread from the 124 forum bass1175 W140 S-Class 1 10-21-2006 08:48 AM
