Transmission Fluid Change E320
31K views 19 replies 7 participants last post by  Kajtek1
#1 · (Edited)
whats the difference in flushing my A/T and just changing the fluid? Most people seem to be opposed to flushing it saying it can lead to further issues. My 94' E320 with 158K on it is kicking into 1st gear and high revving into 2nd. After that its smooth sailing.
Bit of background: I've only owed this car for about a month and I don't believe it was taken care of in proper fashion. As in, I don't believe the transmission fluid has been touch in quite sometime.
I want to isolate the issue by taking care of a few things that I can do myself, i.e transmission service (these Bama boys are trying to charge me 300 to do it...higher at the fancy places) and rear differential fluid.
I plan to buy all my stuff from the dealership and do it myself with the help of my dad this weekend. (My dad i very good at fixing on cars and has done transmission services on other cars many times, so hopefully that will help at bit although its a Benz)
I found a great video for the rear differential fluid change but can't get any specifics through any of the diy guides posted here. If someone could direct me if I'm overlooking it, I'd greatly appreciate it. I saw transmission removal and etc. but nothing on a simple A/T service.
#2 · (Edited)
Flushing to some means running a cleaning agent through it. Don't do it.
A transmission fluid change is rather easy for your model. You should be able to drain the torque converter along with the pan. That will change of the majority of the fluid - about 7 quarts. Refill with 4 quarts, start the engine, then fill in the remaining fluid charge. If it's been neglected, you should also drop the pan and clean it.
For the rear differential, you have a drain plug and a fill plug. It's important to remove the fill plug first. It's difficult to remove. This way you will be sure that you can fill the new fluid once the old fluid is drained out.
#3 ·
If trans is cold, its probably no big deal. If trans does it after a good warm up, then might look into it. Mines quite firm when cold on the 1-2 shifts.
No need to flush, just drain. dont forget Torque converter as well. The trans is an old school 4sp, so no real heavy tech.
#4 · (Edited)
Thanks for yalls info.
The transmission is more pronounced when its cold but I still feel it does it even when its warm. Some guy told me it could be a valve or something like that. Also heard about a B2 piston...
I'm taking the car to be looked at by a trusted shop for them to tell me what they think is wrong. Then go from there...as in, fix myself if I can. I'm a student that just had to have him dream car now...but I'm pretty good at auto related stuff so I feel like I can tackle the aforementioned maintenance s for sure. If it get more serious than that we'll have to see. Appointment is set for friday morning.
#5 ·
You can dial out the firmness and get buttery shifts, but its at a cost of faster wear to your friction plates.
So the firmness of shifts is actually good for making the trans last longer. Just as long as its not banging the driveline apart in the process.
#6 ·
#7 ·
Thanks,
The car is most definitely a joy to drive. I feel very very blessed to have this car and be 25. Get tons of looks in it too!!! The car is truly, as I've heard it mentioned by someone else, a young classic. :cool:
I read the stream that was posted previous to this comment. Thankyou for that information. Very good info there! I want to do as much as I can on this car myself. Gave me the greatest sense of accomplishment when I replaced my lamp switch with a working one and oiled my squeaking blower motor. No need to pay someone else to to that! haha
One quick question, when I drain the TC do I need to plug it back up before I drain the pan or can they simply drain together? I guess this is a sequence question...
#12 ·
You can also turn the torque convertor with a screwdriver/lever since it has little bumps in it...
Turning using crank with a big breaker bar using a mirror or a helper is the best since its not risky or makes scratches on the TC.
#16 · (Edited)
There is no strainer in the transmission.
The filter element is one-time use only and must be replaced with a new filter at every service interval (ideally every 25K) along with a new pan gasket.
Remove drain bolt at bottom of pan and let fluid drain.
Remove drain bolt at bottom of torque converter and let fluid drain.
Re-install both bolts making sure crush washers are present during re-install.
Clean pan and surrounding areas using suitable rag
Remove pan and check for metal filings (some fine metal dust/sludge is acceptable)
Clean inside of pan using parts cleaner tab or brake cleaner solvent spray and let pan dry completely
Remove old filter from valve body. Make sure all remnants of filter gasket are removed
Install new filter onto valve body
Install new pan gasket
Install pan
Fill transmission using conventional high quality Dexron-III (Chevron, Valvoline MaxLife) and fill very gradually until fluid registers on the tranny dipstick. Top off with engine running at full temp. Do not overfill.
#17 · (Edited)
good information! thanks for the step by step. The Dextron III has to be non-synthetic from what I hear...?
the guy that mentioned the strainer was some mechanic that probably didn't know exactly what he was talking about since he admitted that it had been awhile since he had worked on a Benz as old as mine. Guy worked at the dealership which does not have such a good reputation when in comes to the service dept.
#18 ·
The so-called transmission filter is more of a strainer. It is not filtering the clutch dust, just keeping the metal shavings down.
From all the transmissions I service, I have strong reason to believe that the one on 1997 model had factory fluid at around 200,000 miles.
While the filter had only few aluminum shavings in it (I did cut it open) the steel shavings have been hanging on magnetic speed sensor, while bottom of the pan had heavy dust residue and goo-like fluid. Also the top of valve body had lot of dust residue on it. The transmission never had any issues with all of the above, although new fluid made the gear changes softer.
