Was preparing for a long trip and topped up the transmission fluid level because I have a leak that that requires removing the engine, addded about 1l ATF as it was quite low (engine running).
Put the transmission in reverse, but no movement. Same with all forward gears. Increasing the RPM had no effect.
Checked the ATF level again (with engine running) and noticed it was 1 cm above the high mark on the dipstick.
Drained 1/2 liter which brought the level down to the high mark. Still no traction in any gear.
No noises, drained ATF looked like new, no foam.
Stopping and restarting the engine had no effect.
Replaced the shift lever nylon bushings and clips 6 months ago.
Before I remove the engine and transmission from the car I would appreciate any advice on simple fixes/tests to try out.
The first one is to see check the reverse light, would verify that the gearshift lever is connected.
Any other suggestions?
Possible causes?
Possible causes?
