Mobil 1 Delvac 75W90: Fully synthetic, extreme pressure, multipurpose gear lubricants recommended for the lubrication of hypoid differentials, final drives, manual transmissions and transfer cases.
• Excellent lubrication under extreme conditions with easy gear shifting.
• Significantly reduces transmission and differential temperatures.
• Very low pour point, very high viscosity index and shear stability.
• Excellent thermal and oxidation stability.
• Rust and corrosion protection and antifoam properties.
• High load carrying capability and fully compatible with mineral oils.
• Meet API GL-5 & API MT-1.
• Approved against Mack GO-J Plus, MAN 342 Typ M2, MB 235.8 and ZF-Te-ML 05B/12B/16F/17B/19c.
Mobil 1 LS 75W90: A synthetic extreme pressure lubricant used where heavy duty gear protection and high load carrying performance is required in limited slip and conventional differentials.
• Outperforms all conventional gear lubricants with Indy 500-certified performance.
• Minimises wear and spalling in racing and high performance cars.
• Maximum resistance to breakdown from heat and extended high speed.
• Excellent limited slip performance and extended service life.
• Meets API GL-5.
