I realized that I had put the wrong oil in my two differentials. I used RedLine MT-90 which is a GL-4 specification and not suitable for hypoid gears in teh differentials. From the RedLine website (https://www.redlineoil.com/mt-90-75w90-gl-4-gear-oil):
So, I figured this is a good flush for the old fluids and I should just replace them again. I went through the painful process again yesterday and replaced the GL-4 with MB hypoid gear oil, part number 001 989 33 03 12 ($53/bottle) which is 75W85 (the dearler here does not sell the 85W90 required in my user manual!)
I posted the whole procedure here:
http://www.benzworld.org/forums/w21...-front-diff-oil-change-dark.html#post17362706
I did not know the difference between GL-5 spec oil (required for hypoid gears) and GL-4 spec oil (required for gears with synchros) until I did more research.MTL, MT-85 & MT-90 are not for use in differentials with hypoid gear
