it seems like they made the cars during the same years..so is it engine size?
The didn't make them the same years. The 450SL ran from 1972-1980. The 380SL ran from 1981-1985.david7212 said:it seems like they made the cars during the same years..so is it engine size?
I like the second one better.david7212 said:so it sounds like the 450's had more power due to engine size, ane the first two years of the 380 had a poor(er) engine design. ..does that mean the 560 had a bigger motor?...I was just looking at a couple of cars on craigslist...one is a 81 380...and the other is a 84 380...thanks guys
http://sfbay.craigslist.org/eby/car/239805275.html
http://sfbay.craigslist.org/nby/car/239615896.html
560 is the way to go if you can find one you can afford.david7212 said:so it sounds like the 450's had more power due to engine size, ane the first two years of the 380 had a poor(er) engine design. ..does that mean the 560 had a bigger motor?...
Dangdavid7212 said:that article is very helpful...thanks...it sounds like the best idea is to avoid the 81-83 380's....if given the choice
Hello bro',450SLC supercharger said:hi guys .well about the engines here M 117 cast iron called M117 981. and the so called aluminium block thats wrong . its alucil how ever the iron is as u know by now reliable AS HELL and not to talk about the alucil block as well .but i think M 117 981 4.5 liter is more to use when we talking about power and more abuse here.. like my own car.. a 450 SLC 75 using a Vortech T- trim supercharger with Autronic SM4 together with R500 CDI .check the website WWW.AUTRONIC.COM i use to day this setup... Vortech T-trim together with Mondo intercooler air to air so called and Autronic SM4 fully diagnostic management system with R500 CDI power ignition system. Bosch highpressure fuel pump 044 with fuelab regulator .custom fuel´rails and so on.. the engine is bonestock i will send some picture maby u know me from this 450 sel 6.9 supercharged earlier before nutzfore benz he does ...
