2002 E55 110k miles , lost throttle response
7.4K views 23 replies 9 participants last post by  alabbasi
I've been experiencing an odd problem with my E55 which typically occurs when the engine is cold. The car seems to hesitate on acceleration and I have to feather the gas in order to stop it from lurching.
Today, at the light, I had to accelerate a little harder then I normally would and and I lost all control of the accelerator pedal. The car just went to idle regardless if I hit the pedal or not. I'm guessing it's a drive by wire system.
I had to coast to a stop, turn the engine off and restart for the accelerator to come back.
Any ideas?
#5 ·
Thanks , the hesitation is consistent when the engine is cold so if there was a code, it would be tripped every time. I thought it may have been dirty injectors or carbon build up in the intake in the past but given that the throttle completely gave up. I'm suspecting that it's an electrical issue. Still , it should throw an error and i'm surprised that it has not. I'll give it a couple of days in case someone else has experienced the same issue and then maybe run it to the dealer.
Thanks again.
#7 ·
I would check/clean the throttle body (butterfly). I would suspect the cold is causing some carbon or general film on the mechanical components to become too viscous for the throttle motor to smoothly operate the butterfly.
Could be in the electric motor itself but I'd start with some good ole fashioned cleaning of the butterfly.
#8 ·
If I was going to attack this - at that mileage Stabil Marine Fuel Stabilizer ($9 1/2 bottle per intructions) - change out fuel filter with Bosch/Mann ($35 and a few hose clamps) - check air filter/replace (Mann/Hengst ($16) - clean purge valve with MAF cleaner ($9 a can) - any signs of "choking idle" coming to a stop then clean MAF with same cleaner + then have cats checked front + rear rubber/mallet + IR test at temp (free) when cold called "cold rocks syndrome" -
#9 ·
Hi guys, I replaced the fuel filter fairly recently and also the air filters and the transmission filter. This issue appears to be a problem with the drive by wire system. As I said,I lost all control of the throttle... as in I could have my foot stomped on the padal and the car would just idle.
I've still not plugged my scanner in to see if it could pick up codes, there is no check ending light.
#10 · (Edited)
There is a cable attached to the accelerator pedal which terminates into a plastic block under the hood (at the throttle control.) What you describe with having no codes indicates that your plastic retaining block is kaput so when you step on the accelerator, the information is not being sent to the drive-by-wire system, but the return spring in the accelerator makes it feel like everything is ok.
You can see the end of this cable right near the master cylinder.
#13 ·
If your code reader has live data, you can check the TPS parameter to see what the throttle position sensor is reading. Sounds like you may be able to reproduce problem. If TPS is showing closed throttle when this happens, I would guess it may be an issue with electronic throttle and linkages. But symptoms don't sound like a TPS problem--if it were, wouldn't car stall instead of just running at idle?
#17 ·
Ok so i tried resetting the throttle sensor by doing the following and it seems to have gotten rid of the problem on my car.
1- Turn your ignition to on without starting the car and press the gas pedal all the way in for 5 seconds
2-Without releasing the gas turn the ignition off after 5 seconds.
3- Release the gas.
4-Remove key
5-Restart car
#20 · (Edited)
Hi Al
if the codes are the problem for the hesitation then its the afterburner in the exhaust
the codes are for
P20D4 Mercedes-Benz Exhaust Aftertreatment Fuel Injector "B" Control Circuit High
P20DD Mercedes-Benz Exhaust Aftertreatment Fuel Pressure Sensor Circuit
the systems were originally developed for diesels to reduce the particulates in the exhaust. CARB got hold of the idea and they are now fitted to large high end gasoline engines too
there is an "injector" in the exhaust that will add a little more fuel to the exhaust stream if the cats are running too cool. Can be a problem from cold start if the cats are iffy but should not pose much of a problem on an up to temp car unless the cats are not performing.
I believe it can affect the throttle performance in an effort to reduce the emissions, particularly if the cats are cold, but to be honest I have never played with the system and dont know much about the intricacies. I didnt even know they had fitted it to earlier E55 engines.
cheers
Barri
#22 ·
