What springs to look for at the junkyard to increase ride height/rigidity
4.8K views 22 replies 11 participants last post by  tmbrown
#1 · (Edited)
I would like a few more inches ground clearance for my 240D for offroading, as well as more rigidity/better handling.
*A few inches sounds unrealistic. What I'm trying to say is that More is better.
What donor cars have thicker, longer springs that are compatible? I remember mentions of the 300td and possibly all w126? What are the specific thicknesses, lengths that I should look for?
Were 19" the thickest available shim sizes? Should they be replaced with age, since they are made of rubber?
#5 ·
Yeah, that is my plan, to get the Sedan HD springs from the SLS conversion guys. Thanks Greazzer for turning me on to them a while ago. They will go on my '79.
#6 ·
I would love to get a definitive answer about what springs/pads would raise my td 2 inches. I've read everything I can online about it, and it seems like there isn't one answer.
If w116 springs raise the rear, what about the front? What springs would raise the front to the same degree? Also, what springs are in the sls conversion kit? A custom spring? I plan to keep my sls.
Here's how the car sits now. A spring swap (hopefully an inexpensive one) to get two inches is what I hope to do.
#7 ·
Looks to me like your rear is sitting low due to a Self Leveling Suspension issue. Fix that and you won't need the springs. And you'll be able to load it up with many hundreds of pounds while it stays level. Good stuff.
#9 ·
The rubber pads come in 3 sizes to my understanding. The fattest are 19mm. If you add 19mm, you should get around 38mm of ride height increase. Not sure what pad you have now, so you will have to subtract that from the 19mm. So, assuming you had no rubber pads, you should get around 1 1/2" from 19mm pads. If you have 9.5 or 14mm (I think they are the other 2 sizes -- I just went thru the pad stuff when I installed my springs so I should remember all the nit picky details, but I dont), you would subtract that. Assume 10mm (9.5), you will net 9mm or around 18mm in height which is almost 3/4". The SLS delete kit should raise it by a bunch. I original installed the wagon springs in a sedan and look at the rear end of my car ... it's really jacked up. So, the SLS conversion is a great addition IMO.
#11 · (Edited)
Check out this post by DeliveryValve for the information on springs.
And this from him also "Another note is the single color paint mark near the bottom coils refer the height of the spring. With "Red" being short and "Blue" being long springs on a w123."
Here is an example of the long front springs. (also thanks to DeliveryValve)
#18 ·
I don't think there can be anything definitive because in use Springs compress some over time and from Car to Car how much they end up compressed is going to vary. That means what works for one Car may not work on another.
And, then as previously stated there could be several combinations of Spring Pads and Springs.
#19 ·
Well, all our cars are different, but I thought I would do some measuring just to show where my car is sitting.
Pads: 2 nub front, 1 nub rear
Springs: front: 2 red dots to the left of two green dots. I didn't see any blue marks. Rear: no visible marks.
Distance from ground to middle of fender edge: front: 27 3/8". Rear 25 1/8"
So it looks like I could at least go to bigger spring pads. Hopefully that won't change my camber too much. A picture for reference.
#20 ·
What I meant by definitive was something like, "This is what MB intended on the HD setup" and "this is what I have - how do I convert fully to the HD setup?"
2 red beside 2 green isn't a measure by the factory but by the manufacturer, IIRC. Mine has it too (see previous post). Check the bottom rung, or the 2nd to bottom rung, for coloration. This should be indicative of the length.
If you want to measure ride height this is a good reference:
Blueprint
Blueprint 2
#23 ·
My SLS was progressively getting worse, and it would have been an expensive fix to make it workable again. I decided to convert to conventional shocks and springs (cue collective gasp from the td crowd :grin)
Here is what I did:
In back - slsconversion.com rear springs, new Bilstein HD shocks, 19mm spring shims (3 nub).
In front - new Bilstein HD shocks, 2 nub shims, and red stripe springs.
Car rides great, and with a few hundred lbs (costco run w/passenger in rear seat) in the back the ride height stayed where it should and the car handled well. I have not carried a very heavy load yet.
Again, lots of people have good reason to keep the SLS, and that is the best setup if it's working perfectly, but for me converting the rear was the better decision.
Only concern was when I first installed everything there was noticeable positive camber in the rear, but that has gone away after settling in the last 50 miles. I could still go to thicker spring pads in the front for more height (I'm at about 6.5 inches to the skid plate, and about 10.5 inches at the rear diff), but for now I'm very happy with the setup. The ride is a bit stiffer because of the HDs, though. The car really handles so much better than before, and I love the stance. My wife no longer thinks the car looks like a "dog with his tail between his legs".
I hope this information helps someone else facing a similar decision. The slsconversion springs are a very good option if you want a little extra height and/or your SLS is not economically feasible to repair.
