I am taking delivery of my CLS this week and wanted to know who has lowered theirs and how? I understand this a lowering module as an option but has anyone done something different than that?
I'm at 14.5" F & B on my sport II setting, and 27" F & B from ground to fender no washers. What gives? Does II drop even lower with 2 washers?gbmotorsport said:ekovalsy
I went and measured from center of rim to bottom of fender and mine was 14.5" front and 14.5" rear.
I took the washers off and put it back to stock coz I am going to the dealer and see my friend and do warranty work. Nice drop now but I am going to the dealer tomorrow (Monday) and will get the them to drop it down software wise 1.5". Then when the rims get here by end of the month I see if it needs to go lower with your set up.
Thank you for the free advice, I am going to do my W211 E55 the same way when I get it back from the dealer on Monday.
It sucks that we can only go 135 mph on the CLS. I hope we find a way to eliminate that in a cheaper way.
thank you again
gino
Are you 100% sure your front left and rights are exactly the same?I have a question for guys that have lowered their CLS with new brackets.
I'm having a problem with leveling the rear-end of my car. The left and the right side are like 1 inch diffrent, and since there is only 1 braket how can it be so off??? The driver's side has about 0.5 inch of wheel gap, and the passanger side has about 1.5 inches. Do I need to rest the computer or something to level it out? Anyone out there having the same problem??
do you have any other picture for the mod? coz i don't really know where is the part and how to mod the part..Pictures of modifications done on my vehicle
i just did my front with 2 washers, it took about 15 minutes. i haven't done the rear, because the gap appears even with the tires i have. UPDATE: i did the rear by slotting the hole so it can be adjusted. it took about 45 min because i had to jack it back up and slightly adjust to bolts. it does not take much, maybe a 1/8 inch 100PENTX-IMGP4188_IMGP4188.jpg100PENTX-IMGP4189_IMGP4189.jpgI dont know who the question is directed to but I took before and after measurements. I checked the allignment specs and I am still within the original +/- and all id well. The gap is even on all fenders and drops a tad when you park it on the front. It really depends on what washers you use upfront and as far as the holes at the back, drill it to the side towards the rear diff I did about the same thickness as the washers I used. You can also eye ball it and get the same results.
Start with the front first to get familiar with the task. You just need to jack up one side at a time on the front and the drivers rear tire and go under and look at the rear axle pivot, the servo is there. A small 10 mm socket is best to use.
Drop on mine was an inch all the way around. I will redo it when the new wheel set arrives to suit my taste. This mod is fairly simple and can be returned back to OEM in 30 minutes. Thanks to ekovalsy, I dont have to buy the boys at the dealer pizza.lol.
gino
Call AutoWorks in Naples FL. Ask for Tony ( owner).I want to lower my car (CLS550) via star diagnostics...I just can't find anyone to do it! Does anyone know where I can go to have it done in south florida (fort lauderdale/miami)?
