Ways of lowering your CLS
60K views 38 replies 28 participants last post by  stevebower
I am taking delivery of my CLS this week and wanted to know who has lowered theirs and how? I understand this a lowering module as an option but has anyone done something different than that?
#3 ·
No lucking getting any of the local dealers to do it, but you can do it yourself pretty easily and for basically free.
Up front, washers / spacers are added to the brackets for the Airmatic control rods on each side -- the effect is to lengthen these brackets which lowers the front suspension.
In the rear, there is a single control rod anchored to an aluminum bracket, which in turn is secured by two screws through a piece of steel. Shifting this bracket towards the ground / trunk will lower the rear suspension. The bracket is relocated by notching the existing holes in the steel and securing in the new position.
It is very important to make sure the brackets are securely fastened after the modifications. If this is done than the changes should be very safe, and also easy to reverse if necessary.
Parts and tools I used:
6mm metric washers (steel)
6mm tension nuts
dremel with tungsten carbide cutting bit
socket driver and ratchet
Drops of 0.8" - 1" are obtainable with this technique, to go lower you'll need either an expensive electronics module (like Kleeman or Carlsson) or replacement brackets / links.
#10 · (Edited)
ekovalsy.....I found the website, thank you...
Oh and the mods work well. Great tip!!!!!! I had nothing to do so I went for it and it was simple.
That mod took only 60 minutes to do and the results are the same. I just redrilled a hole next to the original in the back unit (located on the driver side rear at the inner axle pivot) and installed 6mm flat washer to hide the other hole and it looks OEM. I will drive back to the shop later today and check the allignment. I do not need the dealer to drop anymore. lol..
I used 2 washers upfront not 3 and it even out the rear. I remeasured from the side step and it dropped even front and rear.
:) thank you again
gino
#12 · (Edited)
Shane24 said:
Maybe this is a stupid question, but I am assuming that before you did the mods, you jacked up the car off the ground, right??
Also, how far did you drill the holes apart??
Also, how much did it drop it by??
I dont know who the question is directed to but I took before and after measurements. I checked the allignment specs and I am still within the original +/- and all id well. The gap is even on all fenders and drops a tad when you park it on the front. It really depends on what washers you use upfront and as far as the holes at the back, drill it to the side towards the rear diff I did about the same thickness as the washers I used. You can also eye ball it and get the same results.
Start with the front first to get familiar with the task. You just need to jack up one side at a time on the front and the drivers rear tire and go under and look at the rear axle pivot, the servo is there. A small 10 mm socket is best to use.
Drop on mine was an inch all the way around. I will redo it when the new wheel set arrives to suit my taste. This mod is fairly simple and can be returned back to OEM in 30 minutes. Thanks to ekovalsy, I dont have to buy the boys at the dealer pizza.lol.
gino
#36 · (Edited)
i just did my front with 2 washers, it took about 15 minutes. i haven't done the rear, because the gap appears even with the tires i have. UPDATE: i did the rear by slotting the hole so it can be adjusted. it took about 45 min because i had to jack it back up and slightly adjust to bolts. it does not take much, maybe a 1/8 inch 100PENTX-IMGP4188_IMGP4188.jpg100PENTX-IMGP4189_IMGP4189.jpg
#14 ·
ekovalsky said:
Glad it worked Gino!
What height do you now have between ground and top of the fender well ? I'm abpit 25-7/8" front and 26" rear. Not super low, but low enough for me. Car is getting lots of compliments too.
ekovalsy
I went and measured from center of rim to bottom of fender and mine was 14.5" front and 14.5" rear.
I took the washers off and put it back to stock coz I am going to the dealer and see my friend and do warranty work. Nice drop now but I am going to the dealer tomorrow (Monday) and will get the them to drop it down software wise 1.5". Then when the rims get here by end of the month I see if it needs to go lower with your set up.
Thank you for the free advice, I am going to do my W211 E55 the same way when I get it back from the dealer on Monday.
It sucks that we can only go 135 mph on the CLS. I hope we find a way to eliminate that in a cheaper way.
thank you again
gino
#15 ·
RennTech Lowering Module... ADJUSTABLE!!
I had the RennTech module installed and it works GREAT!!! It's adjustble so you can lower the front a tad less than the back and gives the car a nice rake. Left front and right front are independantly adjustable as well as the rear. There are four dials in the module (FL, FR, Rear, bypass). There are 7 modes which adjust by 1/8" each.
#17 ·
What wheels are those? they look like my brabus, but I can't tell, any better pics?
#21 ·
gbmotorsport said:
ekovalsy
thank you again
gino
I'm at 14.5" F & B on my sport II setting, and 27" F & B from ground to fender no washers. What gives? Does II drop even lower with 2 washers?
#25 ·
paul i just sent you the few emails i had from someone on the washer method.. the basic principle is that the links in the front have to be longer to trick the computer sensor to lower the car.. In the back the link needs to be shorter to lower the car.. I didnt feel like using the washers and dremel tool to make these adjustments or pay $1200 on up for a module so i used the links i posted on your other thread.. the front links take 5-10 minutes to change out, the back is more time consuming because the car has to be jacked up so you can get underneath it.. If you dont have big hands it's not too hard to get to the link to change it out..
#26 ·
Great pictures, I just have a question. Is the front suspension still strong enough? as it looks like the bracket is the same sort of shape as the 'cradle' or roof of the assemblie. Is there originally any washers there, if there is at least one then I would reckon everything is cool. But if the bracket has no other support except for the 2 or 3 washers does this weaken the system? I have not had a look under there so I may be out of order. Or have you had no issues.
Chris
