Klaus or anyone, can you help me ? I have a soft top w124 e320. The soft top is stuck up. It just suddenly stopped working for no reason. No fuses appear blown in the engine fuse compartment.
If I activate lowering the top, the windows sometimes will go down all the way, but then there is no hydraulic action to retract the soft top. There is no motor noise at all from pumps or anything else. The windows will always go up though once you have closed the two hand levers on the top of the windshield.
I thought there maybe sensor switches that have not been triggered?
Could this be the problem ?
If so, where are the sensors located ?
If not, what else could it be ?
All suggestions appreciated.
Thanks ... David Knaus
