21 - 40 of 50 Posts
Thanks fro moving them. I have been lusting after a camper frame for awhile but being on the wrong side of the Atlantic I dont see one heading my way anytime soon. I already paid some outrageous airfreight bills for my sound dampening floor mats.
When I built my new camper on my U1300L ambulance we debated cutting the box off the subframe and reusing it. Urs convinced me to sell the box as is and build a new subframe that exactly met our needs. A place for the steps to slide up and into, fittings to take the toolboxes, fittings to take the spare wheel slide, etc. Urs bought the collars and we kept the rockers. Everything else was built new. It isn't lighter, it's just as strong, but it fits exactly what we need to go onto or into it.
2666312
2666313
2666314
Discussion starter · #24 ·
Today I've managed to remove the original kipper subframe.
Is this order complete?
Based on a previous post I was thinking to buy the following items:
  • 2x 220 (A 435 612 73 53)
  • 8x 224 (N 910106 014009)
  • 8x 227 (N 913023 014003)
  • 1x 230 (A 425 610 71 41)
  • 1x 233 (A 000 988 45 10)
  • 1x 263 (N 000000 005738)
  • 1x 258 (A 404 992 01 05)
  • 1x 260 (N 910105 016010)
  • 2x 236 (A 435 612 76 38)
  • 2x 239 (N 910105 014017)
  • 2x 240 (A 435 990 72 40)
  • 2x 242 (N 910113 014000)
  • 1x 231 (A 435 610 77 14)
  • 1x 265 (N 910113 024000)
  • 1x 262 (N 000000 004355)
  • 1x 261 (N 308765 024017)
  • 2x 251 (N 910105 014010)
  • 4x 245 (A 437 616 03 20)
  • 8x 251 (N 910105 014010)
  • 8x 254 (N 913023 014003)
Did I miss something? Or is this list not correct?
Dimensions for new subframe
As soon as I have these items, I can start my new subframe.
In the book "Build your own Overland Camper", the author recommends rectangular hollow steel of 100x50x3mm. What dimensions do you have?
How much space do you recommend between the original and the subframe?
In the Mercedes manual you'll find a subframe that consists of 1 beam in the center. Most of the subframes I find on the internet contains 2 beams. What would you recommend?
Thanks for your help.
Ivan
Ivan
Ivan, if you had been on this forum long enough, you would know that the (my) Universal Answer is: It Depends.
As for list, I don't have access to EPC, and don't have a U3000. If you miss something, you can always place another order. Basically, you want the two simplest cross-beams (no vee cuts), and hardware. The long bolts and sleeves are critical; they are the bump stops that limit angular motion of the subframe and body, before they would crunch the cross members themselves.
I am a very firm believer in highly integrated design. Without the first pass at the design/ layout of your camper, there is no absolute way to answer any of the remaining questions, except maybe for one.
1) On the Atlas subframe, the longitudinal tubes are 80 x 80 x 4 mm wall thickness. I am pretty sure they are high strength steel, what we in the US would call an A50 steel (typical structural shapes are A36 grade). This makes a big difference in the tube size/ wall thickness required to meet a given load condition. By using higher grade steel and then cutting a LOT of lightening holes, Atlas can make a very light frame.
Further thoughts, not in order posed:
A) Manufacturing methods and materials are highly relatable to quantity of items produced. M-B is producing a lot of frames, relative to Atlas. Therefore, they employ different means to achieve the (same) desired result. M-B can justify stamped and special roll-formed sections, as the cost of dies, etc. is quickly repaid in time and material savings. I suspect that the single large rectangular section (in the M-B manuals) is due to these considerations, as opposed to "best way to build a subframe". For Atlas, stock sections are imperative, along with plasma cutting and custom bending of plate materials (which is pretty cost effective at their quantities). For the solo builder, the "Brute Force Method" generally has to prevail, due to sheer cost and availability of special equipment. What this is getting to is, you have to decide whether to pay for high strength steel, whether to do lightening holes, etc. A lot of this comes down to what your skill level is in both engineering and fabrication, or what you can get help with. As noted by others, simpler and heavier may be a perfectly fine solution. However, weight does carry a penalty, of some sort or another.
B) Engineering. Two beams help distribute the loads of the camper body onto the subframe, which can be an important criteria. If you are going hard-core high tech for your shell (carbon fiber, perhaps?) you can use the shell to self-support side and end body overhangs beyond the subframe. If the shell (read: floor) is not designed with an appropriate structure (it may be lighter, as well as cheaper), then you will need to consider a full perimeter frame, to pick up the wall loads directly, and prevent the floor bowing down over the ends of the subframe. The Atlas subframe is quite a bit undersized, relative to the body that it supports.
C) How much space.....?? Not sure now to address this one. See 3.2/ 121 of the M-B manual that you posted, which has a note to see further specs. I presume there is more information available from M-B.
Atlas lowers the top of the subframe relative to M-B standards. Michael D. told me it was 75 mm lower, which is the amount they bump up into the floor of their bodies, to maintain adequate clearance over the tire/ shock tower. When I measure my U1300L firebody, I have the top of subframe only about 28mm lower on the truck frame rails than the bottom of the metal floor/ top of frames of the existing firebody. One thing is certain, that the center of the F&B pivot bolts must both be coincident with the top of the truck frame rails at the rear, which is the higher of the two. Atlas maintains this, as well.
So, after the long-winded lecture, here is the cross-section and dimensions (blue)of the existing firebody on my U1300L RW1. The section and dimensions (red) of the Atlas subframe are also shown. All dimensions are CNC type (see zero/ zero labelled) in millimeters. The sections are composites, that show relationships, NOT one true section, all in order to show shock tower clearance requirements and tire location and clearances.
Disclaimer: This is NOT an engineered drawing. For Reference ONLY. Any user must make their own decisions as to actual design.
But it might help the effort.
Lee
EDIT/ ADDED:
B.1) I believe there is good support (!) for the two beam approach, on a pure engineering basis. M-B makes the point that MOST of the load is transferred from expedition body through the subframe to the TWO clamps that wrap the tubular truck frame crossmember. Per the Atlas section, the two tubes stack directly over the clamp locations. Two cheeks with gussets, and shear connections between, are a very efficient design, per the load path. Forms a braced square over the tube, which is itself the basis of the rigid structure. The subframe stays in harmony with the tube, and therefore the center of, the truck frame. Also quite amenable to individual construction, no special shapes required. And the (half) load at each clamp is then distributed along the length of the body by the associated square tube. The gussets and triangle plates to carry the pivots then brace the pair of longitudinal tubes against racking (torsional) forces. I like elegance, and this design has it.
Edit:
Forgot to add the new dimension from top of Atlas frame down to top of 365 tire. It is reduced by 28 mm, so it is172 mm here. Obviously, clearance to bottom of actual floor/ tire well of body is a dependency, and must be built to suit.
2667180
Ivan,
Have you considered increasing the allowed weight of your U3000 instead?
I recently bought a U3000 (long wheelbase) and believe it weighs 6.5t currently. This will only increase as I convert it to a camper.
I believe the U3000 can fairly easily be increased to 9.5t.
You would need to take a HGV test (Class C in the UK) but it would mean that you’re not always worrying about being overweight when you’re full of fuel & water....
Dan.
Sent from my iPad using Tapatalk
Discussion starter · #28 ·
I haven't weighted my vehicle recently. But this is my best guess:
GVW: 7.500 kg
  • allowed freight: -900 kg (according to the original papers)
  • removed crane: -1.000 kg (the manual said 950 kg, but I added 50 kg for the remote controller)
  • removed trailer coupler: -100 kg (my best guess)
  • removed kipper: -400 kg (my best guess)
  • removed heavy-duty subframe: -350 kg (my best guess)
So I guess that I currently weigh 4.750 kg. That leaves me almost 3.000 kg for a new subframe, a second fuel tank and the living box. When I look at Bliss Mobil they mention 1.800 kg total dry weight for a 13' container.
I really would like to go to a vehicle scale. It's only a 5 minutes drive. But I don't have any license plates on my vehicle and it is not insured at the moment. So I won't take the risk. I've looked at renting mobile vehicle scales, but they are not available until end of January.
Ivan
Discussion starter · #29 ·
I'm currently creating my new subframe. The distance between the subframe and the bump stud is about 20mm. On the drawing in one of the previous threads there was a distance of 55mm shown.
Do you think I should increase the distance between the subframe and the bump stud?
Ivan
2683237
2683238
2683239
I would increase the distance.
That subframe looks strong (heavy) enough to mount a crane on.
C.
Discussion starter · #33 ·
I'm not intending to drive in really tough conditions. After all, when the expedition vehicle is ready it will have cost me a fortune (even if I try to do as much by myself). I am the cautious type with my equipment.
I'll increase the distance to 55mm as shown of the drawing prepared by @photobldr . That's also the distance used by Atlas4x4 if I read the drawing correctly.
The material has a thickness of 5mm. So we still can carry it with 2 persons (this wasn't possible with the existing subframe for the tipper.
When I asked Mercedes Belgium this morning, they advised me to go for 70mm and they've sent me a picture of an army vehicle. But this seems like overshooting.
2683375
Thank you for this thread, lots of information and documentation.
I am working on my 404soft top to convert to camper with cabin and box attached similar to van style fire trucks.
These frames are different but I would have expected that all frame mounting and pivot point would have been in one plane.
In the mounting of implements pdf. The pivots are at the top of the frame but the central mounts are not in the same plane since they straddle the transverse tube. I would think that that would create side loading with extreme frame flex. Maybe insignificant? Anybody could give more indepth explanation why MB did not put the in the same plane.
The frame flex in the drawing is noted as 7.5 degree, Can I assume that is measured from the center hard mount relative to the pivot rear mount. Does that imply that the front pivot mount has also 7.5 degree relative to the center hard mount, so 15 degree total? would the flex be linear over the whole frame length?
My 404 seems to be different in that aspect. Any similar implement mounting documentation for the 404 available?
In the subframe I just acquired I want to move the hardpoint which is now in the center to the front and extend the cabin similar to a DOKA . Any info available on where the cabin front pivot is situated relative to the pivots in the rear? or how the van style fire truck is setup?
Any input on the frame flex from a fully loaded 404 and how this is distributed over the frame length?
Thank you,
Johan
I'll increase the distance to 55mm as shown of the drawing prepared by @photobldr . That's also the distance used by Atlas4x4 if I read the drawing correctly.......
I would absolutely not set the subframe at only 20mm off the bump studs. M-B and Atlas use a greater distance, and they have the experience and testing abilities to know. I do not think it coincidental that the total geometry of frame to bump stud is virtually identical for both. Atlas is the lowest overall top surface for a subframe, but they do not skimp on the angular articulation. That should resonate with anyone doing their own engineering.
In the mounting of implements pdf. The pivots are at the top of the frame but the central mounts are not in the same plane since they straddle the transverse tube. I would think that that would create side loading with extreme frame flex. Maybe insignificant? Anybody could give more indepth explanation why MB did not put the in the same plane........
The frame flex in the drawing is noted as 7.5 degree, Can I assume that is measured from the center hard mount relative to the pivot rear mount. Does that imply that the front pivot mount has also 7.5 degree relative to the center hard mount, so 15 degree total? would the flex be linear over the whole frame length?..............
If you look at the measurements that I posted in #16, focus on the relationship of pivot centerlines (coincidental and approximately equidistant from the transverse clamps) to vertical offset of the clamp bracket plate that wraps the transverse frame tube at the rear axle. Centerline of the F/B pivots are only slightly elevated above the top of the tube (add half circle clamp piece and rubber collar thickness to the cutout dimension in the plate, as shown). A cross section of the truck at the transverse tube shows a braced rectangle, which one can assume is a "hard point", no relative motion. I presume that M-B knows that there is very little frame flex in the fore and aft direction, so the vertical offsets of the pivots and tube remain essentially constant, and very nearly planar. Life being what it is, this is probable not absolute, but close enough for working trucks (rear body loading will fall primarily on the transverse tube, which coincides with the axle location, and therefore axle articulation forces/ frame torsional flex will dominate).
Per drawing of post #25, the 7 1/2 degree articulation is the angular limit of frame flex at the crossmember, per my measures and graphical analysis. The rotation is relative to the center of the pivot bolt, exactly as drawn and dimensioned. This applies equally to the front and rear crossmembers. pivots. What this implies is that the frame can wind up torsionally +/- 7 1/2 degrees between the clamps at the frame cross- tube and the location of either F/B pivot.
For Ivan, if you are creating your own frame design, you need to consider a couple of things. If the 855/ 905 mm F/B offsets are greater on your truck, then you need to allow for a greater angular articulation. And the flex characteristics (less or more??) of your U3000 may not be the same as the U1300, further complicating the issue. That may be why M-B told you 70mm, or they might not be seeing the whole picture.
And, to pile on, the spacing distance is less critical than is the angular limit. Ivan, if you change relationships of pivots to frame/ subframe from what I drew out for the U1300, then you need to look at the angular first and foremost. That is, if the pivots are lower, relative to the bump studs, then the relative motions before hitting the studs can also change, as you are making more of a sideways arc at the stud, as opposed to a more vertical motion. That would mean more distance when relaxed, to allow for the same angular motion.
Johan, I try not to speak of what I know not, and I know not of 404's, so I am of no help here whatsoever.
Lee
Discussion starter · #36 ·
Lee,
Thanks for your reply. I've increased the space to 55 mm as shown on your drawing.
The dimensions 855/905 are very similar to mine. According to the builder's book these dimensions are 856/905. In your drawing you have 390 mm from the pivoting point to the bolt. This is identical.
Discussion starter · #37 ·
In the mounting guide I've found the formula to calculate the space.
h = x * tan Ăź
h = 390 * tan 7,5°
h = 51 mm
But I can't figure out how Ăź should be calculated.
ß = l x 4 [° / m]
2683682
Discussion starter · #38 ·
The sub frame is ready to be painted and treated for rust. Last month I've invited the Belgian Unimog dealer to take a look at our work and he proposed to create some extra space between the sub frame and the rear springs. He had no other remarks.
The bolt in the bushing is to protect the thread during painting. After all, that's where I drew wire for a grease nipple.
Lee,
Hi, first of all sorry to refloat the thread, but I'm struggling in a search of a subframe for my truck U2450L/38 with 3850mm so, I'm wondering where you find this pdf, and where or how can I get one similar for my U2450l/38 or if this will work also. I think I'll end to made my own subframe, with the headaches that will made for me.
Thanks!
You can do it with a local shop. There are threads on here that show the mounting system - basically there is are Left/Right rocker pivots, one each at the front and rear of the subframe (attached to the frame), and then in the middle, there is a pair of front/rear pivots effectively, which clamp onto the tubular crossmember.
This galvanized frame is fitted to a U2150 in France.
The 'Builder's Handbook' for the SBU series has been posted on this forum. I don't think I have it, but others do. If I find it, I'll post it.
The Red Arrows = Left / Right Pivots
The Yellow Arrows = The clamps on the crossmember.
21 - 40 of 50 Posts
