The SRS light comes on and goes off as it pleases. The mechanic tried to pull the codes but did not get any, I am not sure whether he was pulling from the wrong ports or his instrument is bad. He said that the main module may be bad and it cots more than $1,000 to fix and it is better to leave it alone.
I have read the posts here that if it comes on and off intermittently it is just some bad connections or sensors and not the SRS main module itself.
It goes off sometimes when it goes over bumps - I think so but it might be wrong, sometimes it goes off immediately - after 10 seconds, sometimes it stays on. Please let me know where to start.
The mechanic also said that the airbags are old after 10 years, but will they work if the SRS has been fixed or it wont. let me know, thank you for the inputs
