Hello,
I recently inherited my dads W163 ML 320 from 1999:
The SRS/Air bag lamps wont turn on during start up. Seems like the opposite problem most people have.
I hooked up an OBDII-reader (iCarsoft MB II) and got the following codes from the air bag module:
B1153-00 - "Child seat / DTC Status: Fault indicator lamp on"
B1153-15 - "Airbag off malfunction indicator lamp discontinuity / DTC Status: Fault indicator lamp on"
P020200
P02026e
P00026e
P0258C0
B1476-00 - "SRS airbag malfunction indicator lamp A1e15 discontinuity / DTC Status: Fault indicator lamp on"
B1476-01 - "SRS airbag malfunction indicator lamp A1e15 short circuit / DTC Status: Fault indicator lamp on"
P000200
P00026e
P025800
P0258D0
The first thing I tried was changing the battery and checking all fuses. After reviewing electric diagrams it seems like the a1e15 light is connected through fuse f16? Ive attached the pdf. This model havent got the aux fuse box underneath the passenger side, just 1 main box.
I removed the dashboard and changed the lights into bulbs I knew worked.
I have looked at the rat nest underneath the fuse box and checked where the air bag module is, but havent seen anything out of place (as in loose or damaged wires)
So:
I took the car to the local merc dealer, but they advised me it would be more expensive than the cars value to even diagnose the problems.
Not sure where to look for the errors and would greatly appreciate any pointers what to do. Im not that great with cars but would love to learn.
P020200
P02026e
P00026e
P0258C0
P000200
P00026e
P025800
P0258D0
So:
