Don't go to a Dealer or service station just to change that sensor ,you do this type of repair yourself including oil & filter changes , even spark plugs if you have a little idea of how to handle a spanner , if you do ,then there is no need to spend extra money to someone (like it has just shown for you ) to make your car defective or get it back with a defect ,it's very common with our W140's in general .
Here is the Sender you need>>
Mercedes R129 W140 URO Sender Unit With 2-Pin Connectors 0095420817 | eBay << , you probably find it even cheaper by a couple of bucks ,not worst the effort .
Organize a little bucket (size of a Coca Cola can but wider) where some oil can drip into when you remove that sensor ,oil will come out then stop, park the car on a level surface or between a road & high Kerb so you can slip under it ,no need for a jack this way . Unscrew the sensor , screw new one in & it's done , make sure you get a new Copper O ring otherwise it will probably leak drops of oil , easiest repair on the W140 M119's & M120's .
You can even change that sensor from the top if you have long arms & a little patienz,all you need to remove is the air intake hose on the side of the sensor ,Location is directly underneath the oil filter with a twin wire to it .
Alternatively , buy the Sensor and go back to the guy that changed the oil , he should do it for free to you since he was the cause , you just being nice buying the sensor ,soo ... you know what I mean ,just be CAREFUL they don't brake something else in the process like these mechanics always seam to do ,fix one thing - get paid but brake another thing to get paid even more ,that's way no Mechanic touches my car ,been there done that never again.:thumpsup:
