I have an 08 E320 Bluetec, 77,000 miles. My car has the gummed up/carbon buildup on the intake manifolds as well. Here is the history:
1) Oil leaked from a deffective EGR membrane on the swirl motor, and fried it. I had it changed at the dealer ($1200) at about 70,000. Car had gotten a check engine light and the boost was restricted with poor acceleration (semi limp home mode). It was drivable, but not fun (0-60 would take forever and had to shift gears manually to get toyota prius acceleration).
2) Now, 7,000 miles later, the car has gone into limp home mode a few times very intermittently, without triggering the check engine light. Restarting the car clears the problem. Dealer quoted me $4300 to replace both intake manifolds. They do not want to clean them. They will replace the swirl motor under parts warranty, but will not cover any labor.
By the way, I use mostly speedway gasoline from NW Indiana, which does not have any biodiesel. Sometimes I put BP. The mechanic told me to stop putting speedway diesel and to put BP or Shell, as they are higher quality. Sounds like BS to me. In retrospect, I should have insisted that they check for carbon buildup when they had the car apart and clean the intake manifolds if they find problems. I doubt this carbon buildup is from the last 7000 miles. Why did the mechanic not see the gummed up manifolds the first time. Supposedly now my motor is fried again because the valves do not move easily because of the carbon buildup. But when I took the car to the dealer there was not check engine light.
What do you guys suggest? Any hope that MB will step up and cover this repair, on a car with almost 80K miles. I bought this car (MB and diesel) for longevity, not to replace 4 yrs later. Just bought a 2012 Passat TDI, 6 speed manual. I wonder if it will have the same problems.
-Mike-
08 E320 Bluetec
