Has anyone used these iCarsoft scanners; MBII or i980 with the W210?
If successful did you need to connect to the 38 pin underhood connector or just the OBDII?
Did you get full function on scanner?
They list the W211 but not the W210 as one of cars the scanner works with.
Here is a list of the features of the MBII from their site;
iCarsoft MB II for Mercedes-Benz / Sprinter / Smart_Benz Scan Tools
MB II is a professional and powerful vehicle fault diagnosis tool developed by iCarsoft Technology Inc. With a 4” TFT LCD and unique diagnostic software,it features full ECU diagnosis of single vehicle brand and test modes mainly include: CANBUS, ISO9141, KWP2000, J1850 etc.
It enable technicians to accurately diagnose complex problems.
Feature:
• MB II can do it all-reads and clears trouble codes on all the systems such as engine, transmission,
ABS and airbag etc.
• Read Data Stream
• Full ECU Diagnosis
• Applies to the entire models of MB equipped with OBDII-16 DLC
• Easy To Use With Metal Dome Keys
• Oil Light/Service Reset:Support service lamp reset, Brake pad reset function, Steering angle sensor calibration etc.
EPB:Opens and closes the brake pads,Reads and clears EPB/SBC trouble codes,
• Turns off the ECU and brake warning light,Diagnoses EPB/SBC caliper functionality,
Resets the brake pad thickness service etc.
• ABS/AIRBAG
iagnoses ABS/ SRS system codes,
Reads/clears codes of ABS/SRS system and turns off ABS/SRS warning light,
Performs bi-directional tests such as cycling the ABS solenoids, Retrieves ABS/SRS ECU information etc.
• ETC
• For more functions, please contact us for function list !
Feature:
ABS and airbag etc.
• Read Data Stream
• ABS/AIRBAG
• ETC
