Hi All
I have had my S500 W220 2000 for about three months and overall I am pleased with its performance except for an annoying vibration.
I did a search and posted this before and got a lot of advice on Tires and Wheel balancing. I have had my wheels balanced three times with no effect.
So I took the car to Pedders Suspension specialists to have the suspension checked out. The first guy I took it to said the Joints were worn and the shock absorber was blown on the front driver’s side. I did not fully believe his diagnosis so I took it to a bigger Pedders Shop and they only identified the blown shock.
Airmatic
I do not have any air leaks but I am wondering how the airmatic suspension damps vibration.
I would like to fix the problem but I am unsure if the problem lies in the control system or in part of the strut.
I have attached the Pedders Damping test results and you can clearly see that the RH strut is not damping the vibrations imposed by the test machine.
Advice on where this problem lies would be greatly appreciated.
PurdieMerc
Sydney
Australia.
Airmatic
- Is there a hydraulic damper within each atrmatic strut ? or
- Does the airmatic system do the damping via some sort of adjustable air circulation orifice controlled by the damping switch on the dash, providing the suspension damping settings of soft, medium and hard.
- How does the adjustable damping system work on Airmatic ?
PurdieMerc
Sydney
Australia.
