I have a 2007 C230 with 160k miles that has been showing high negative long term fuel trims for some time now and I haven't been able to resolve it.
When I first noticed the issue the LTFT for both banks were around -25%, no DTCs were showing yet. Now the LTFT are -29% and -31% and it is showing a P2180 (To rich off idle bank 2).
This is what I had tried/tested so far:
The O2 sensor readings were a little off so I swapped them all out (never been replaced so fairly old) but that made no change.
The MAF has been replaced but reads the same as the old one, roughly 3.4 g/s at idle. What should I expect here?
Checked for any vacuum leaks (I know this would drive it lean though) and all looks good. few older cracking hoses I swapped out but nothing looks to be leaking.
Vacuum looks good measured all around the system, stays solid over range of RPMs.
The secondary air system seems to be functioning just fine, the blower blows, the vacuum valve switches over and I can hear the valves open/close using a vacuum pump.
Fuel pressure stays very constant at 60psi. Is this too high? Ive seen posts saying this is in range and others saying it should be around 50-55, if its too high this could be my issue. The fuel pump is pretty new, the old one went bad so I replaced it with a new straight from the dealer.
With both banks negative with similar values and no other DTCs I dont think its a leaky injector issue but I havent tried to test for that yet. Feels like they would all have to be failing at roughly the same rate to cause this and not have other issues.
Any ideas on other things that could be causing this condition?
Brian
Brian
