I spent all day trying to get it starting.
No fuel is coming out of the injector lines at the pump. We swapped out the glass bowl strainer underneath the pump, and pumped and bled until we found no more air was coming into it.
Still no fuel at the injector lines.
Started disassembling hoses for better inspection, when looking at the injector pump to the left of the bleeder (whats the screw for in the bleeder?) there is a banjo bolt. This is a bolt in a bolt, on the MW pump there is a spring and a ball in there to regulate fuel pressure, is there supposed to be a spring and ball in there on the A pump?
No more air seems to be coming from the return line, if I pump with the primer pump should fuel be coming out here?
I got one more day left in Miss to get this fixed, please help!
