Hello,
So about a month and a half ago I was having Limp Mode troubles. Every day driving, Limp mode would hit me sooner or later. It would also give me Check Engine Light. (Not able to shift past 2nd gear). So then I took it to a mechanic and he cleared the transmission codes and then ever since then I never had that problem again... Until today.
Today I was driving and then I noticed the RPM's were getting a little high for the speed I was going. (20-30 mph) And remembering this was a sign/cause of Limp Mode, I tried to Tiptronic to go into 4th gear (my way of testing limp mode because it doesnt shift past 2nd) and Sure enough, The test failed. I was in limp mode. But no Check Engine light like when it was happening before. :crybaby2:
So I turned the car off and on to get it out of limp mode, hoping it was just a minor issue, Got to work and then left it there for a few hours. On my way home from work, I noticed the RPM's were getting high again so I tried 4th gear and couldn't get into it. Limp Mode again. Again, The interesting part is that its not showing any kind of Check Engine Lights or bringing up any kind of codes, Unlike before. Took it to AutoZone to get any possible codes checked that may be hidden and no codes came up.
So whats the next step? Does this sound like any thing particular? Any body with this problem before?
Any help would be much appreciated!
