I had both these codes stored in memory. The check engine light is coming on and off. Sometimes it goes away for a few days, but will then come on and go off, sometimes in the same day. I read the cam timing sensors with a scanner when the light was off and this is what I am seeing out of the ECU.
at idle at 2500 rpm
exhaust left -19.95 deg 3.46 deg
exhaust right -19.98 deg 3.40 deg
intake left +36.27 deg +32.7 deg
intake right +36.45 deg +33.0 deg
Are these normal cam timing readings. I erased the codes and drove the car for a day and no lights came on. Read ECU again and there are no pending codes. Does this sound like the balance shaft issue? My 2006 C230 has about 94,000 miles on it.
at idle at 2500 rpm
