Subby- Thanks for explaining the $400 Mercedes scanner, before i wasted money on it! :beerchugr:
--- 1) Where is the crankshaft position sensor located anyway, on 2001 SLK? :dunno:
--- 2) What website do you use to find location of parts?
--- Do the Facelift SLK's have a different location than this? (i see a sensor there, but the wire is coming out of the side, not the "top" as in the photo)
http://www.pelicanparts.com/techart...echarticles/Mercedes-SLK230/21-ENGINE-Crankshaft_Positioning_Sensor_Replacement
However, this diagram shows a similar location, just with the wire coming out of the sensor's "side":
(hmmm, so maybe on the Facelift SLK's-- they just made the
wire a "right angle", but the Sensor and Location remained the same)
Mercedes Benz Workshop Manuals > SLK 230 (170.449) L4-2.3L SC (111.983) (2001) > Powertrain Management > Ignition System > Sensors and Switches - Ignition System > Crankshaft Position Sensor > Component Information > Description and Operation > Crank
Yeh, i agree and don't *think* the culprit is the "crankshaft position sensor", but this post is confusing me:
According to this post:
http://www.benzworld.org/forums/r17...forums/r170-slk-class/1263021-k40-relay-circuit-associated-11.html#post13185553
"If when trying to start the car the starter motor turns the engine over, but the car just won't start .... crank position sensor is the problem, not the K40"
"If when trying to start the car the starter motor is dead, the radiator fan is on full blow, and the temperature gauge shows cold .... K40 is the problem not the crank position sensor"
"Also, When the crank position sensor and the MAF failed, the check engine light came on and there were codes which helped identify the problem. When the K40 failed, there was no check engine light."
*Remember, i have no CheckEngineLight on, & my car cranks, but doesn't start. (when my battery is charged)
Update & Plans
i haven't been near my car for a few days.
I still have to charge the battery, it keeps dying in a few days (maybe a "parasitic draw" somewhere)
https://www.youtube.com/watch?v=KF1gijj03_0#EricTheCarGuy
I didn't solder the *right* way: i used solder from a plumber/handyman friend, without Flux!
So i'm going to buy 60/40 Tin/Lead Rosin-Flux Solder, and re-do the solder
https://www.youtube.com/watch?v=Zu3TYBs65FM#ChrisFix
I might just buy a new K40.
--- 3) Does anywhere have a
K40 cheaper than Parts.com, $148+tax?? i think part # 1705450205
I'm going to borrow a "Fuel Pressure Sensor" to see if the fuel pump is sending fuel.
Last choice: i'll try to get under my car on the hill, to measure voltage
if i am getting "Fuel Pressure" to the engine, then i'll buy a "crankshaft position sensor"
Thanks again everybody, i appreciate any help :smile
