Old 01-12-2007, 09:09 AM   #1 (permalink)
oztds's Avatar
Date registered: Oct 2006
Vehicle: Two 1998 SLK230s, 2003 SLK230 SE
Trouble Code P0341 - effect?
I have been having an issue with intermittent power - sometimes the car will accelerate well, other times it won't (as if the suprecharger isn't effective) . I pulled out the codes from the engine and I have a P0341 - camshaft hall effect sensor fault code.
Can anyone tell me what the practical implication of this fault is? Could it be related to the intermittent power problem? Where is this item located? Could be just a loose wire maybe?
Any help appreciated.
oztds is offline   Reply With Quote
Old 01-12-2007, 09:31 AM   #2 (permalink)
Date registered: Dec 2006
Vehicle: 2000 slk230,firemist
look on yesterdays posts, just so happens theres a great discussion on this very fault
ganndallff is offline   Reply With Quote
Old 01-12-2007, 03:48 PM   #4 (permalink)
oztds's Avatar
Thanks guys. Looks like the very thing - same symptoms and same code. Will check the plug & wiring and if OK will try to get the sensor changed Monday. The car will be in the shop tracking down the problem anyway, so at least I can tell them the most likely culprit.
Old 01-13-2007, 10:31 PM   #5 (permalink)
Vehicle: 1997 SLK230 K & 1978 280CE
Sugest you try engine live data on your new Carsoft Multiplexer
Mine gives a reading for Hall Sensor Camshaft of 85/170 (alternates) at idle
When I disconnected the Cam Sensor the reading was 255 and Code P0341 was set
Looks like the Carsoft will pay for itself with the first scan with the problems it has shown up.........
David in Australia is offline   Reply With Quote
Old 01-13-2007, 11:05 PM   #6 (permalink)
Bazzle's Avatar
Date registered: Apr 2005
Vehicle: 1998 SLK230
80 / 160 on mine.
Havnt pulled the plug yet. Next time
Bazzle
Bazzle is offline   Reply With Quote
Old 01-14-2007, 12:51 AM   #7 (permalink)
oztds's Avatar
Yes, just did that. 85/170 on mine when the engine is cool. When the engine warms up it stops working (255) and the code P0341 is set. Tried all of this today. Car ran beautifully till temperature climbed and I could actually pick the point at which the sensor stopped working. I don't know how many shop hours this will save me, but lots. So far the MB workshop guys have been clueless on this problem and I was going to have the whole air intake system pulled apart tomorrow by another European car specialist. Now I'll ask them just to replace the sensor. Will still cost $ no doubt, but much less than it would have without the diagnostics.
Still no clue on my PSE fault - shows faulty without a code. I cleared it today but it still shows a fault. No other symptoms so I guess it's a communications fault of some kind. CarSoft is a bit opaque and doesn't allow you to drill into the diagnostic data. Does anyone have the CIS that accompanies CarSoft?
Old 01-15-2007, 05:46 AM   #8 (permalink)
oztds's Avatar
Just to close this off... replaced camshaft sensor today - hey presto, runs like a new car and accelerates very well with just light throttle. Problems solved, thanks to all who helped.
will the radio code effect this? tjobeid R129 SL Class 11 04-28-2007 01:39 PM
trouble code PO366 ajydog W203 C-Class 4 09-22-2006 11:29 AM
Trouble Code P0170 MACSL R129 SL Class 2 07-11-2006 01:27 PM
trouble code eo 13 barry putnam W140 S-Class 11 08-27-2005 11:21 AM
OT: Need Help, what is trouble code P0300... ike W163 M-Class 3 07-09-2003 05:35 PM
