Well it finally happened to me. Three times. The old broken wheel bolt issue.
I purchased a complete rear axle assembly from a junk yard. He told me he could not get one wheels off. I told him to send as is and I would get it off. It turns out there were three broken wheel lugs. So I made myself a drill bushing and tried to drill a 1/8" pilot hole down the center of the three studs. All was going good until I got near the spherical seat which I at least needed to get beyond. I now know that MB heat treats the bolts from the top of the spherical seat to the end of the threads. using good quality new cobalt steal drill bits.
the drills went down about 1" without issue then came to sudden stop at a point just above where the spherical seat is. Changing bits did not help.
Then I remembered I had one drill bit that I was highly impressed with and figured I would give it a try. It was a number 3 bit ~1/4 so it would have been the next step up in my drilling anyway, and I was piloted enough that I could use it. This bit is called a super long life bit from McMaster Carr see
https://www.mcmaster.com/#drill-bits/=1eeilqf
This bit drilled out the stud to the required depth without any significant problem. Needless to say these will be my new replacement drill bits. These bits are not even cobalt. They do have a cobalt version at about 3 times the price but these beat the standard McMaster Carr cobalt by a long shot.
So for the moment Im stuck until I get a 1/2" diameter Super Long life bit of the Carbide tipped bit I ordered from Amazon comes in.
First couple of pictures show the 1/8" cobalt bit in the drill bushing. Last picture shows the Super Long Life bit with its purple coating.
