The Nylon Fuel Line came in late this afternoon. I was able to route it, had to be careful because there are two fuel level sending units in this tank, one on each side. The Nylon hose comes in a coil like a rope, it wants to stay in the coil. Getting it to route proper means you need to persuade the nylon to stay in the proper shape. I ran some TV COAX cable into the nylon 3/8" hose, I had read that others used old spark plug wires for this purpose but I did not have one handy so I used the Coax cable., the Coax TV cable was just about the perfect size to fill the hose opening. With the Coax installed I warmed the Nylon hose till it was almost hot to the touch and was able to bend the Nylon hose into the shape I needed. Of course you also need to hold it in shape as it cools to be successful. At the Fuel Filter end of the tank the nylon needed a 90* elbow and that came out well also. I worked the straight part of the line about 1' at a time with the heat and used a fan to cool it quicker. the 90* bend was only about 4" of the tubing and I did this bend all by itself to hold the proper shape while it cooled. Without the Coax cable inside the hose would just collapse as you heated it and tried to bend it. With the Coax in there it was pretty easy to form. The fittings do not want to go into the Nylon and there are a few techniques to use to install a fitting into the nylon. Youtube had several videos showing a variety of ways to do this. I have a tubing flaring tool already so I used it to hold the new Nylon hose tight while I tapped the fitting into the tube. Worked perfect with only a strong mix of soap and water for lubrication and gentle quick hammer taps to install one end but the other was slightly larger and I had to use a little heat along with the soap and water to tap the fuel pump end into place, the fuel pump fitting is a sharp 90 and there was not much I could tap on without worry of breaking the fitting. Quick taps moves the fittings into the hose, you can watch the fitting slip in as you tap. Both went in and fit very nice. fittings are barbed to help hold the pressure from the fuel, to remove the old hose off the fittings a gentle slice with a razor blade is all you need and the hose will pull right off. Be gentle with your cut because the fitting needs to seal against fuel leaks and if you cut the fitting it could create a leak path. I went ahead and added cinch clamps to both ends of my hose but I think they were not necessary, the factory did not use cinch clamps. The new fuel line looks good, fit very well and should be as long lasting as the factory part. Got the Pump module and the new fuel pump access cover completely assembled tonight and ready for install again. Hopefully I have time tomorrow to get this car running again. The Tank and rear differential have to be raised up at the same time on this install because the tank fill tube and vent tube both route through the rear differential assembly. While raising the units you also have to reinstall both coil springs. Once this is done the emergency brake can be hooked up, then the driveline installation, all the heat shields and finally the exhaust. A bit of work still to do.
With a little practice the nylon is not bad to work with. I am glad to know this product now. My wifes BMW X5 has a nylon hose on the intake that failed, I spliced it with a rubber fuel hose to fix it and it works but now I see making a new nylon hose is not much of an issue.
