Well, my old car lost this and never fixed it. Really wanted it on my replacement vehicle and it was working. Now, just like my old car loses pressure and eventually the pump shuts it down. With these older cars it seems like pulling the fuse recovers, but frankly the pump has been reset when the battery has been disconnected. Both cars will inflate for a time, lose pressure and pretty quickly the pump shuts down the line.
I am ready to tear into the cars and would like a diagram (syljua's links in another post are dead). Better would just be a verbal on wear to look. I swapped the dials on my old car to no avail. I intend to listen to both of them closely for a leak, but their is nothing obvious (one car I test drove had a hissing sound coming from passenger seat that was obvious). My hope is just to work my way along capping the line as I go. I believe the hose comes from the pse to drivers seat at the dial, then to drivers lumbar, then out of lumbar to passenger seat dial and then finally passenger lumbar. I am not real sure of path of line from driver's lumbar to passenger dial. Hopefully I can cobble together a working system for the new car.
Bladders are $180 a piece from the dealer. Sorry to say I won't pay that. I'd rather jamb something in the drivers seat as a permanent adjustment (saw a post here on that). I saw someone else used an inflatable neck support, but no detail. I suspect bladder is a part that goes so used is not attractive. I suspect even the dealer part may be rather aged and might not hold up all too well. Are the bladders patchable like a bicycle tire?
