Adjusting AIRmatic Levels
1 reading
15K views 15 replies 4 participants last post by  rudeney
I have an ML 350 from 2006 and it has air suspension, but I have recently experienced that the car does not stand evenly but that one side is lower than the other. After a bit of searching on the internet, I have not found anything that has helped me, so I turn to you for help.
How can I get the levels right on my car? What do I do if it is still skewed, what could the error be then?
I use an XTOOL PAD3 to troubleshoot and adjust the air suspension.
I got the following error code now on the car and on the screen it says "Disturbance" which means that I can neither raise nor lower the car's air suspension.
DTC Info: Level calibration was not successfully carried out.
Status: Stored and Current
At the moment, this is the setting found on the air suspension.
Left front vehicle level 11 mm
Right front vehicle level 33 mm
Left rear vehicle level 38 mm
Right rear vehicle level 19 mm
#16 ·
Bonjour
j'ai exactement le même problème avec mon ml de 2006
Vous avez résolu le problème?
Welcome to the forum - please take a moment to read the information on the links below. It explains how to use the forums and update your user profile so that your car's details and your location appear on each post below your avatar. This is good information for others to know when trying to help. It also has good information about how the forums are organized and how to use the search feature:
Find your Forum Section, Navigate & Search
Complete your profile.
You are replying to an older thread and the OP has not been seen since. If you have a problem you need help with, please start your own new thread with as much specific detail as possible - that will get you the best assistance from fellow forum members. Also, please understand that BenzWorld is an English language forum. If you want to participate in our discussions and you do not communicate in English, I suggest you use an online too to translate your text to English before posting.
