Hello all. I've got an e280 wagon and a mechanic didn't do up my starter motor + - connections tightly so I was having starting issues. I took my intake apart and inspected my throttle body which had bad wiring on inspection. I rewired the throttle body myself but I must have done something wrong because the car doesn't get any throttle position signals and just keeps the injectors on idle capacity so when you rev it runs lean and can't get above 1500 rpm. Sometimes it'll stall if you rev to much around 1500.
I have looked for a diagram of the inside circuit board pin designation. There's diagrams for the car's writing system but I doubt there will be a diagram for the inside of the throttle body.. The throttle body loom goes into the throttle body via a seal and then all the wires are soldered to a circuit board, maybe I melted some layers of the circuit board together too but idk.
So yeah are there any pictures of the pin # + where it goes on the circuit board. Cheers
My theory is that either the gauge of the wiring I used isn't compatible, I put a pin number allocation on a different pin but I doubt this because I literally did them 1 by 1 so it's impossible. The solder looks fine.
