I checked for fault codes and have several misfire codes and a random misfire fault code.
Here is what I've done so far;
1) Tested ignition coils and I getting power but no ground power (plugs are not sparking)
I've already previously replaced the crank position sensor last year.
2) I removed connector to ckp but I'm not getting any power or ground to the sensor, so I'm thinking maybe a bad relay?
3) check for fuel pressures and its good
Can someone help me with a wiring diagram for the crank position sensor circuit? Need to know were the power or ground power to the ckp sensor comes from.
