A 98 129 is a great car, and so is the 140, they share many components and idea's.
The 140 is sightly heavier than the 129 and the suspension wish bones can be shot,, you need to get the car on a lift and crow bar the inner bushes, while under there check all ball joints and roll bar components.
Check the vacuum locking and check that all the switches all work including the air con, also the seats if fitted.
Check the brake and fuel pipes for rust.
Over here we say allow a couple of ÂŁ1000 to get the car perfect.
The drive will convince you, the 129 drives very well, but the 140 even better, the cornering is as good, but you do it all in near total silence.
I have had some super help on here, all a very nice bunch as there are not that many in the UK.
Good luck with it.
