Hi All,
I'm new to this site. I'm hoping someone can help me. The car smokes terribly. White smoke with the smell of unburned diesel fuel. Car runs so-so. Mostly it's a smoke problem. I've checked the injectors - they work. Cleaned the throttle body. Used Diesel Purge type product. I tried adjusting the injection timing. Nothing makes a lsting difference (short term improvement but gets worse all the time).
I'm wondering if the injection pump diaphram (governor) has a whole in it and I'm getting too much fuel for the amount of air the throttle body allows. If I suck on the tube it doesn't hold vacuum (engine off); shouldn't it? if I pinch the tube while the car is running the throttle goes up; however if I remove the tube the throttle goes way up as I assume it should.
Any thoguhts?
Thanks,
Greg
Any thoguhts?
Thanks,
Greg
