Thanks for this very helpful information, Martin. Much appreciated.
I am going to need to go with a much lower cost solution for diagnostic testing as I will only be in Saudi until next May ... I will be forced to sell the S500 just before leaving. Essentially, I need to get through the next few months with a low-cost solution to diagnose any issues before taking the car to mechanics who are notorious for trying this and that to fix MB cars as the shops do not invest in proper diagnostic tools like the MB Star C4 you have noted.
While perhaps not the best solution, I am thinking of at least getting this unit to offer me some feedback on what is happening with the S500.
Mercedes 1988-1995 OBD1 code reader
Off topic here but this is the reason I started looking for an OBD diagnostic tool. Transmission Gear Clunky Shifts and Limp Mode Incident.
I should note that after turning off the car and waiting a few hours before restarting, the Yellow ASR light has not since lit up and the Limp Mode has not returned ... so far. I have driven the car three times since the one time only Limp Mode incident. Previous to the Limp Mode, the Yellow ASR light had been coming on after a few minutes of driving the car with this happening over the last few weeks on a regular basis. Sometimes the Yellow ARS light did not come on.
If the issue of the Yellow ASR light coming on and the one-time Limp Mode activation occurrence are transmission fault issues, then I plan to start by changing the 13 Pin Connector on the transmission alone with the tranny filter and gasket and see if this resolves the issues.
A few symptoms regarding the transmission behavior are likely worth noting.
1) The shifting from 1st gear to 2nd gear and 2nd gear to 3rd gear feel clunky ... not smooth. 1st to 2nd is smoother than 2nd to 3rd gear.
2) The transmission rarely seems to go into 4th gear although this may be because I do not drive the care over 110 kms per hour and the rpms are around 2,100 at that speed. Maybe a little higher at 2,300 but certainly not higher than this. I have on a few rare occasions driven the car faster and barely noticed a gentle smooth shift into 4th gear. I am wondering is this should be the way the 1st gear to 2nd gear and 2nd gear to 3rd gear shifts should actually perform and feel like .. smooth and barely noticeable. I am considering adding a quart of Trans-X Automatic Transmission Slip-Stop and Leak Fix as recommended by Kent Bergsma on his YouTube channel video
This idea does scare me a bit as I worry I may end up making the transmission worse instead of better.
As noted, my original intention was to find a low-cost diagnostic solution to try to establish what is going on with the transmission, Yellow ASR light coming on, and the Limp Mode incident. That being said, the immediate concern is to find out what is going on with the 722.6 5-Speed transmission.
Car has 224,000 kms on the odometer. Just over 139,000 miles.
