I am starting a fresh thread as the issues with my 1996 S500 W140 are now transmission related as the primary issues.
Here is the background on the issues.
The car is a Japanese import car and I drive the car in Saudi Arabia.
Transmission should be a 722.6 but I have not gotten under the car yet to verify the part number on the passenger side rail. Will confirm this ASAP.
Chassis 140.051
Year: 1996
Model: S500 W140
Bought the car 3 months ago with 220,000 kilometers on the odometer.
Transmission has had hard shifting from the day I bought the car. Slower acceleration made for gentler gear shifts. Faster made for harder shifts.
About two weeks ago the yellow ASR light on the dashboard started coming on a few minutes after driving the car. Once the car was turned off then started again, the same pattern would occur.
Tried the reset shift points by turning key to second position, holding down gas pedal 15 seconds ++, then turning key off and waiting 3 minutes without anything on in the car and doors kept closed, then remove key, put key back in and start car. Resetting did work and the car's acceleration and power of the engine improved. However, shifting remained hard.
Yesterday, I removed the TCU unit to inspect for transmission oil and the unit and the wiring harness are dry and clean. No issue there. I also removed the ASR module and the module closest to the firewall, maybe the Base Module .. not sure, and all units were clean and dry.
After reinstalling all three computer modules, the ASR light on the dashboard was on all the time unlike the previous situations where the ASR light would only activate after driving the car for a few minutes. Now it is on as soon as the car is started and it stays on all the time.
I decided to do another transmission reset today and "Oh No" ... now the transmission will only shift from 1st gear to 2nd gear ... no 2nd gear to 3rd gear. I tried resetting two more times and no change. I only have 1st to 2nd gear. I drove the car up to 100 kms per hour to see if 2nd gear would shift to 3rd gear at a higher rpm but no luck.
As I am not starting from a standing stop in 2nd gear, 1st gear is engaging, I do not think I am in Limp Mode .... but perhaps I am wrong.
The question now becomes, where do I go from here? I will follow the steps MAVA has offered in his feedback in my "What OBD2 Can Read OBD1 with 38 Pin to 16 Pin Adapter" post.
Strategies I am looking at are to replace the following transmission items on the car. As I figure importing parts to Saudi Arabia takes time, I am best to change as many parts as possible rather than attacking this as a one-by-one resolution to the fix. This explains the extensive list of replacement parts.
Transgo SK 7226 Shift Kit 722.6 96-17 - I believe from the picture that this kit includes a Regulating Pressure Control Valve Spring. - Not 100% sure this kit fits my 722.6 transmission as I am seeing "Yes" and "no" answers about fitting.
https://www.ebay.com/itm/SK722-6-Transgo-Shift-Kit-Mercedes-Chrysler-Jeep-Sprinter-722-6-NAG1/253687824457?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D52885%26meid%3Ddec75fa21721450593155123588c6526%26pid%3D100005%26rk%3D1%26rkt%3D2%26sd%3D112316599924%26itm%3D253687824457&_trksid=p2047675.c100005.m1851
If the above Transgo Kit is not compatible with my 1996 722.6 transmission, then I intend to buy the following item.
722.6 Transmission Regulating Pressure Control Valve Spring Sonnax 68942-01
https://www.ebay.com/itm/352093619705
GooDeal 722.6 Solenoids Set 6 Pcs for Mercedes Benz 5-SPEED Automatic Transmission
https://www.amazon.com/Transgo-7226-Shift-722-6-96-17/dp/B0725V864M/ref=pd_rhf_dp_s_vtp_ses_clicks_1_2?_encoding=UTF8&pd_rd_i=B0725V864M&pd_rd_r=NYSZZG6CAM1J7HYTQ4G3&pd_rd_w=8tDQO&pd_rd_wg=EOmLT&pf_rd_i=desktop-rhf&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=05d75987-58ed-4d36-bbfa-515cd87e4ee3&pf_rd_r=NYSZZG6CAM1J7HYTQ4G3&pf_rd_s=desktop-rhf&pf_rd_t=40701&psc=1&refRID=NYSZZG6CAM1J7HYTQ4G3
Sonnax 6841002K Bearing, Input Shaft w/ Sealing - Not sure if accessing the area to install these parts requires dropping the tranny. If so, I will try the other repair startegies and leave this as a last resort.
https://www.amazon.com/Sonnax-6841002K-Bearing-Input-Sealing/dp/B071P63Z73
Sonnax 68942-05K Overlap Control Valve Sleeve Kit
https://www.amazon.com/Sonnax-68942-05K-Overlap-Control-Sleeve/dp/B01IDCIXUK/ref=pd_sbs_263_4?_encoding=UTF8&pd_rd_i=B01IDCIXUK&pd_rd_r=d2f8e20b-b5c9-11e8-96dd-777fa7fb2507&pd_rd_w=UtkCm&pd_rd_wg=MoJjF&pf_rd_i=desktop-dp-sims&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=0bb14103-7f67-4c21-9b0b-31f42dc047e7&pf_rd_r=VKYVR8VYYR3W8CZWNR5T&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&psc=1&refRID=VKYVR8VYYR3W8CZWNR5T
Bapmic Transmission Conductor Plate + Filter + Gasket + Connector Adapter Kit for Mercedes-Benz 722.6
https://www.amazon.com/dp/B01NCKQKWP/ref=sspa_dk_detail_0?pd_rd_i=B01NCKQKWP&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=a54d13fc-b8a1-4ce8-b285-d77489a09cf6&pf_rd_r=586X8AVV98B5W5X5J3FS&pd_rd_wg=Huxwt&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&pd_rd_w=d3q3z&pf_rd_i=desktop-dp-sims&pd_rd_r=6da8226c-b4f6-11e8-b96a-75051c3f57a5&th=1#customerReviews
Strategies to Improve Engine Performance
I intend to replace these two parts.
Mass Air Flow Sensor
https://www.ebay.com/itm/New-Mass-Air-Flow-Sensor-Meter-MAF-For-Mercedes-Benz-0280217807-0000940748/281131753624?fits=Year%3A1996%7CMake%3AMercedes-Benz%7CModel%3AS500&hash=item4174c22098:g:uVwAAOSwUKxYbv85#vi-ilComp
Fuel Injectors Part No. 0280155217
https://www.ebay.com/itm/8X-OEM-Upgrade-Fuel-Injectors-0280155217-for-S500-S420-5-0L-4-2L-Mercedes-Benz/292716252983?epid=1517828385&hash=item44273f8f37:g:3rAAAOSwO95bkfia
Sourcing Lower Cost Parts ???
If anybody has any tips on where I can source lower cost parts, your references would be greatly appreciated. I expect to leave Saudi in 9 months or so and selling the car will return very little money to me as old cars just are not valued here at all. In fact, I will lucky if I can sell it all so I want as little money in the car as possible.
Looking For Somebody in USA
As I am in Saudi Arabia and many of the sellers who have the items I need do not offer International Shipping, I am hoping to find someone on the forum who would assist me by allowing me to order the items to them and then once the shipping price of a box of the combined items is available I can send the money for shipping before the person ships my items. Ie. Looking for a Mercedes Good Samaritan
Thanks in advance, everyone.
JubailW140 [David]
Chassis 140.051
Year: 1996
Model: S500 W140
JubailW140 [David]
