Update added 20170903. All of this information plus more is now on the w220.ee knowledge base at
https://w220.ee/WIS_83.40_Automatic...tomatic_Climate_Control_(ACC)_or_Heating_Ventilation_and_Air_Conditioning_(HVAC)
Original post continues.
Now that I know I can edit an uploaded post I would like to share my research to date on the Automatic Climate Control (ACC) Hidden Menus.
It is very much a draft and I do not wish to seem presumptuous, but as a retired scientist/engineer and a newbie to this Forum, I found a lot of the information on the ACC on the various Forums confusing, and often conflicting. My way of unravelling the information was to list each piece as it was discovered, often by chance, in an orderly fashion, and to then condense it down to as many basic facts as possible.
Hence the attachment was formed.
I then performed many tests in an attempt to reverse engineer, ie discover by testing and analysis, what the information really meant and the range of parameter values.
I know that the information is incomplete and there are bound to be many errors so please post any changes, additions and corrections etc and I will edit and repost. That way the document will hopefully evolve into a definitive one for the W220 ACC. Itâ??s a pity we donâ??t have a Wiki based system available and then you could edit the document yourself.
Note extra information is needed wherever there is:
TBD means "To Be Determined".
TBC means "To Be Confirmed".
?? means "Don't Know".
Regards,
Brian
PS I was able to fix the issues with my ACC (mainly fluff on the temperature sensors and aspirators), which now works exceptionally well.
PPS I am very keen to find out what Parameter NR.78: Heissland {Hot Country} means as it seems particularly relevant as it is Summer in Australia now with temps in the high 30C's.
PPPS I do not have access to a STAR Diagnosis Assistance System (DAS), but it has been ordered, and this may help with some of the issues.
Search Key Words: W220 2003 Update S500 LWB S-Class Automatic Climate Control ACC Automatic Air Conditioner AAC Heating Ventilation and Air Conditioning HVAC Hidden Diagnostic Menus Residual Heat and Ventilation REST Recirculate Buttons Typical Value Parameter Range
Later Note: Updated attachment to Version 2 so the Knowledge Base grows!
Regards,
Brian
