Hi Guys,
Had to defect from W220 Forum for this one :grin
It's a customers car, I'm well versed in older CDI's and Star DAS, but not so on this model, also a bit of a noob to Xentry App too, as this is one of the "newer" Cars I deal with, although probably the worst condition wise :laugh
Sooooo I want a little advice please :wink
It's a W212 203, an E250 CDI Wagon, 6 Spd Manual Trans, and a dog of a car, 141684 miles, used and abused, little maintenance, fix it when it stops mentality
Car has a shed load of other un related ABS and Lighting codes and problems, but the main Engine Power Loss issue is this..........
It is very down on power, even after a full code reset, with no codes showing at start of test drive, and before the EML light comes back on.
From Cold, first drive up the road it went like a rocket, but by 3rd gear EML was lit and it was waaaaay down on power.
Using Xentry, when the car arrived at my Workshop today, the Codes I got upon first read were :-
P246397 DPF Soot System Function Restricted
P226300 Boost Pressure Deviates
P00AF92 Boost Pressure Control Malfunction.
P208064 Temp Sens 1 Cyl Bank 1 Malfunction, Implausible Signal
P262700 Connection for Trim Resistor 02 Sensor 1 Bank 1 Short to Earth
P068500 Output for Relay Circuit 87 Electrical Fault or Open Earth
After clearing them, and a short drive, the first and second codes came back, EML doesn't come on when the first one appears, but if I try and push car hard it then puts up EML and 2nd code. None of the other codes came back today.
I reset them several times, and found if I drive it gently it feels OK, and no EML, but even so it puts up the DPF Soot Code. Can go for miles and miles like this, but as soon as I push it harder, then up comes EML and Boost Pressure Deviation code flags up.
My gut feeling is that the DPF is blocked with Soot, and because of the blockage the Boost Pressure can't get up hence the second code when trying to go faster.
I could not find an option in Xentry to do a forced Re Gen, nor on Snap On Solus :frown
Am I looking at fitting a new DPF first, and then praying it's cured ??
Is there a Re Generation Option in Xentry ??
Can anyone shed any light on this ??
Cheers Dave
Cheers Dave
