W124 wheels/tires
18K views 18 replies 16 participants last post by  plinker17722
just bought a set of W210 sport wheels, 16X71/2 ET41.
couple of questions. will they fit without modifications? what size tire is correct? what tire sould i buy? the car is a '94 E320 sedan.
just redid the suspension and brakes, bilstien sport shocks and struts, stock springs and pads new rotors and pads all around, new diff mounts and steering damper, etc.
car will be my daily driver and will receive no other mods. just normal daily driving, no agressive hot roddin'. i do like to drive in the twisties with a little "verve" on occasion. all comments welcome. regards, michael
#11 ·
- To put wider tires you need lower ET, ET41 is bit on the higher side, factory wheels that came with ET41 used 205/60/15 from what I remember.
- For rim width of 7 1/2 ideal Tyre width would be >= 215, based on your requirement ET34/37 would have worked.
- Additionally you need strut travel limiter + fender modification, there are many threads with this info here.
#16 ·
While searching for Monoblocks I just now bumped into a set of 16" R170 SLK wheels with 16x7 ET 37 (205/55-16) in the front and 16x8 ET 30 (225/50-16) in the back.
Would those work in my Wagon? Kind of thinkin the fronts have too much ET and the rear too little... Comments, anybody?
