On a 1977 450sl where would the turn signal relay be located? Its before mercedes combined it with the hazard unit.
Check your bulbs or replace the flasher. I replaced the flasher and all is wellMy turn signals and flashers blink at the the same speed an Uzi spits out 9mm's. I suspect it is the relay but I don't know where the relay is on this car. Is it part of the hazard switch itself or separate and somewhere else? If separate, where is it?
Thanks.
