Update - I need some advice and direction. The engine temperature gauge moves to 120F within one minute of starting the engine, but the thermostat housing is not warm to the touch.
After diagnosing and replacing the OVP relay, the vehicle was able to start, but I noticed that the temp gauge was moving up quickly. Not knowing all the service history, I decided to change the coolant, thermostat, and temperature sensors on the thermostat housing; as well as the belts. Temperature sensor A005 542 10 17 was found to be in bad shape and was replaced with a Mercedes part of the same number. After starting the car the temperature went up to 120F but the engine felt cool. I pulled the wire from the sensor and the temp gauge seemed to turn off.
When changing the belts I found that the water pump seemed to turn freely without grinding and no play in the shaft. Also no visible coolant leaks.
Any assistance would be greatly appreciated.
Thank you.
Dang!
Yes, from your description, it does sound as an electrical anomaly.
I could be wrong here, but from afar, it sounds as though there could be something else/another circuit trying to find ground through the temperature gauge.
Instrument cluster grounds.... ?
Scratching my head here, I'm wondering if perchance there is a
bad engine to chassis ground here?
As an aside here, we saw clutch cables fail prematurely do to that very condition/cause & I
do remember a spectacularly unnerving speedometer failure on my 1980 Volvo one morning a really long time ago. LOL. Yes, there was odd indicator movement, then a lot of evil smelling smoke, in my face & all at once. I digress, sorry....
Here is the temp gauge electrical schematic for you. Hope it sheds light.
Looking at the circuit, its pretty simple really. You disconnect at the sender.. voila... so I don't believe the cause to be an issue
downstream of the temperature gauge.....
There's obviously a lot of equipment powered up once the ignition is ON.. like everything..
To isolate the cause, how about removing all the fuses, save the ones needed to run the engine.
Start the engine & observe the temp gauge and add fuses [one at a time] see if you can duplicate the condition.
Should you be able to recreate it, you'll have have a pretty good handle on 'what it is NOT' & conversely, where to look.
Here are some more diagrams of
Power Distribution this time.
Again, good luck.
M
