Hi, is there a diy for tail lamp gasket replacement? is it easy to replace? mine is still ok but im worried after 9 years its due for replacement. thanks
Hi , you mean to do this on the new gasket or can be done on the old gasket sticked on the tail lamp?Hi ZFT:Hi, is there a diy for tail lamp gasket replacement? is it easy to replace? mine is still ok but im worried after 9 years its due for replacement. thanks
There is another option you may wish to consider, and that is applying some dielectric grease to the rubber seal.
Dielectric grease contains silicone, and will not deteriorate the rubber gasket.
Quite the opposite, dielectric grease will keep the rubber gasket in good, pliable condition, and will provide a resistant barrier against water intrusion between the rubber gasket and its mating surface.![]()
Dielectric grease is relatively cheap, and easily found at most auto parts stores.
Try it.... you'll like it!![]()
God Bless, Arctic
