Speedometer question 1988 560SL
1 reading
2.9K views 17 replies 9 participants last post by  oldairguy
My speedometer and odometer stopped working. After watching several videos on Youtube, I have now realized that the speedometer is not manually driven. Questions: Should I be looking for an electrical problem/connection? Where does failure typically occur? I have seen that the Odo gears fail, is this a separate issue or will fixing the speedo problem fix both? Is steering wheel removal mandatory or does removal just make job easier? TIA. I have searched forum but didn't find any threads that answer this.
#5 ·
I need to get back there to fix my odo but the screw to get the wheel off is stripped so I gave up but if anyone has a picture of how they were able to access i’d love to see that and give it another go. I’d like to fix the odometer before I put too many “ghost miles” on it. it came to me working so I think it’s relatively accurate.
On a similar note, an ethical question. Do I try and wind it forward to add the miles I think I drove since it broke or leave it as is and tell the next buyer someday to add a thousand miles or something?
#8 ·
Huh. Give up. What's that? There's a solution to every problem.
Next time you attempt that screw get some heat on it with a pencil torch. Gotta melt the loctite.
#9 ·
Hi Uncle,
For access to the instrument cluster removing the steering wheel (and a small plastic cover underneath) is mandatory and takes only 2 minutes. 2 screws from the backside, holding the airbag and one center bolt for the wheel.
If you use a torque wrench (they have a much longer shaft then a normal wrench) and a second person to hold the wheel, it won't be a problem.
Don't try it alone or with non appropriate tools!
Your odometer system may have an electrical problem, removing the i-cluster and perform some measurements will help to find the root cause. If you don’t have an idea where or how to check the wiring/signals, you should better don’t start working on this.
Cheers Martin
#17 ·
Drill about a 3/8" (10mm) hole all way through the bolt. Then drill using a 3/4" (19mm) bit just deep enough ~3/8" to pop the head off the bolt. With the head off the bolt the torque is now released in the bolt and you will only be fighting Loktite. At that point if the easy out gives you any problem apply the heat as required. Drilling using left hand bits is always optimal.
Note a 3/4" drill bit is too small to touch the splines in the wheel hub and should break the cap off the bolt long before you touch the steering shaft.
