Having been frustrated over Mercedes’ no longer updating W221 nav maps (since 2014), I have looked over a number of solutions to replace our navigation system. The best seem to involve adding either Apple CarPlay or Android Auto to our existing system. Some involve replacing COMAND screen, others involved adding boxes that leave wiring visible. I decided to try a device marketed as a SmartBox, which promised no wiring splices, no visible wires, and provides both Apple CarPlay and Android Auto either wired or wirelessly. These are available for 2006-2013 (2007-2013 North American designation) W221s (COMAND NTG 3.0 and 3.5). They also supply versions for many other Mercedes models. The device I purchased ($499) is sold by https://carplaysmartbox.com or Mercedes Wireless Apple CarPlay Solution – Joyeauto Technology; and while they provide screen mirroring and also the various applications available in CarPlay or Auto, my principal focus is on navigation. I wish I could say the installation was plug and play and setup simple, with everything working smoothly; but that is not the case.
My sole relationship with these sellers is as a customer.
The biggest problem is the installation instructions provided. I will document the difficulties I encountered during installation, and the result (bottom line, so you won’t have to read further): CarPlay is working with my iPhone 11 Pro Max, and I have navigation maps depicted onscreen (Apple Maps, Google Maps, Tom Tom Go and WAZE), but I have not been able to get spoken turn-by-turn instructions. I have been able to get notifications of upcoming turns via the haptic “thump” by my Apple Watch on my wrist, which means I do not have to keep constant (and unsafe) watch on the screen; but a benefit is that when I am listening to music, it does not fade for the spoken instructions. Essentially, the device can be used successfully for navigation, with current maps (as long as you keep your phone updated; also, apps with downloadable maps do better than those dependent on cell towers) – but its installation can be vexing. In the posts that follow, I hope to point out those difficulties with their solutions, and save you some grief. This will not be a full set of installation instructions – just a highlight of some of the problems and photos showing the correct installation (where the instructions I received were wrong) so you won't experience the problems.
It took me about an hour to do the first install, but as you will see, I did many installs and removals - now it takes about 30 minutes total to remove and reinstall. Then, there is time required for setup.
IF YOU DON'T WANT TO REVIEW ALL THE INSTALLATION STUFF - but just want to know how it works, here is the short version. All of the features of CarPlay work normally EXCEPT voice turn-by-turn instructions, as mentioned; the W221 (at least with COMAND 3.5) cannot be set to allow that to work by any Mercedes-authorized changes to the Audio settings via DAS (I have not asked an Indie to make them). My workaround is the Apple watch, mentioned above. Once installation is complete and all the required setup has been done, there can still be some annoying things each time you start to use the system, mainly concerning music not playing properly. There are some hints that help get everything working together smoothly during the startup sequence at post 22. But once you get it running, the system is great; it just should not have been as difficult as it was to ge there.
