1 - 20 of 24 Posts
· W221 & Audio Moderator
2015 S550
My dealer informed me, and MBUSA has now confirmed, that there will be no more nav map updates for NTG 3.5 (MY 2010-2013 S-Class and 2010-2014 CL). The last release was BQ 6 46 0341, v.14.0, for calendar years 2015-2016.
The MB nav map update site for MY 2007-2009 S-Class and CL indicates that v.15.0, BQ 6 46 0340, also covering calendar years 2015-2016 is the last release for NTG 3.0 systems.
Personally, I find that infuriating. V.14.0 was the only update for NTG 3.5 after the 2013 model was produced. Its road data dates from 2014, and it contains errors that were a problem even when the discs came out (among other things I am constantly told to take an exit on I-275 in Tampa where none exists; they were detours during road construction). Cutting W221 and CL owners off after just one update is simply ridiculous, and will have me looking at other brands for my next car purchase.
The message for NTG 3.5 owners from MBUSA said specifically:
"We can confirm that there will not be additional navigation updates for the NTG 3.5.
"We appreciate the time you have taken to share your thoughts We welcome your feedback as it is invaluable in our on-going efforts to provide a product that meets the demands of our customers.
"While we cannot promise this will change in the future, it is comments such as yours that help us to provide feedback to the appropriate individuals within our organization, so they can consider improving upon the features available for our products."
That language suggests that perhaps with enough feedback from W221 and CL owners, perhaps they could reconsider and at least one more update might be released. I note that for the '05-'06 W220s, map updates were released covering dates through 2014, eight years after the last W220 was produced. Here, we get three. That is a sorry decision by Mercedes, and we owners should say so. The email address is [email protected]
Thanks loads, Mercedes! I will certainly keep this lack of support in mind the next time I go car shopping.
So, for newer maps we are left with workarounds. There are several ways to get smart phone data displayed on your COMAND screen. That can include the maps, including those with turn-by-turn instructions, often used in iPhones, Android phones, and iPads.
One such solution was presented by member hilarushi at Mirroring iPhone and Android phones on COMAND - it is a wireless solution using the phone as a wi-fi hot spot transmitting to a wi-fi rebroadcaster (such as Anycast) with an HDMI output that in turns feeds into a device that converts the HDMI output to analog RCA output (https://www.amazon.com/s/?url=search-alias=aps&tag=youcanic-20&rh=n:15684181&field-keywords=HDMI2AV+Converter), in turn feeding into the MMI aux inputs that can be selected and displayed on the COMAND screen. One would have to use that somewhat balky setup with a Video In Motion device (I would recommend the one by NAVIKS, having used one for a brief time). The setup can be used with either iPhone or Android.
A second method is wired; using an Apple Lightning to HDMI output cable (Lightning Digital AV Adapter - Lightning to HDMI), one that then connects via an HDMI cabe to the same HDMI-to-analog device used in the wi-fi connection above. Selection of the RCA video is again made on the "Video" menu of COMAND. I do not know if iPhones having 30-pin output will work as well, but there are a number of HDMI adapters for various Apple devices. I have not explored similar cables for Android.
A third method is to use a video interface such as that by NAVIKS - 2010 - 2013 Mercedes-Benz S-Class (W221) HDMI Video Integration Interface. It is also used together with an iPhone HDMI interface, and North American cars require a Video In Motion bypass device as well (2010 - 2013 Mercedes-Benz S-Class W221 Video In Motion). All together, including additional cables, etc., your'e looking at nearly $650 for a DIY installation.
All of those methods transmit audio together with the smart phone map display, so you can get turn-by-turn instructions. None of the methods offers nav data on the multifunction display. The first two methods involve a bundle of unsightly wires that would need to be hidden, and require a power source. Frankly, I would only use such a setup if I were traveling in an area I am totally unfamiliar with, and I'd be tempted to do it just using an iPad instead of using all that stuff.
There is also a fourth method, which actually involves replacing the OE COMAND monitor. It involves a replacement unit (the monitor, in any case) for COMAND 3.0 and 3.5 that offers Android compatibility, but as yet it does not offer Apple CarPlay. See W221 ANDROID touchscreen... - MBWorld.org Forums (but you'll have to sort through some snarky posts - sorry) - but this site says its unit offers both Android Auto and Apple CarPlay compatibility (via a 4G hotspot). Also see DLAfever's posts further down in this thread. (A source for the device is at US $649.0 20% OFF|Qualcomm 10.25. I have no experience at all with this system, and its cost is around $675 depending on options..
There is also another device for adding Apple CarPlay OR Android Auto to your existing screen. This is not a screen replacement (which, I believe, add a wi-fi hotspot to the car for connection to the phone; please correct me if I am wrong). Contact info for the product below is NavTool). Product selection, pricing etc. are available via NAVTOOL INC. The first link below provides a demo of the Apple CarPlay capability; the second shows installation and programming.
One more option has come to my attention: CarPlay Smart Box Home - Get Wireless Apple CarPlay In Old Car. (also available from a company called Joyeauto, https://www.joyeauto.com/category/wireless-carplay-androidauto-solution/mercedes-wireless-apple-carplay-solution/ - however, installation and use has not been without problems. First, they sent the wrong printed instructions; second, when provided, even the correct instructions were vague about connections to the COMAND unit (silly me, I thought the connectors might be color-coded - wrong!). The DIP switch settings given were wrong. Worst of all, once I got wireless Carplay running (this unit also had provisions for wired CarPlay, screen mirroring and Android Auto), I found there was NO WAY to get voice turn-by-turn instructions, either through the car's audio system or from the iPhone. By enabling "Notifcations" in Maps, I was able to get my Apple Watch to ping for upcoming turns, so I did not have to stay focused on the screen. I would have preferred voice turn instructions, but the haptic thump on my wrist works nearly as well. Also, while the support folks were responsive and courteous, the techs were not; they insist on video, and will not accept still photos, of problems. For the full writeup see SMARTBOX ADD-ON FOR APPLE CARPLAY AND ANDROID AUTO
2007 S550; 2014 ML350
My dealer informed me, and MBUSA has now confirmed, that there will be no more nav map updates for NTG 3.5m (MY 2010-2013 S-Class and CL). The last release was BQ 6 46 0341, ver. 14.0, for 2015-2016.
Already, the MB nav map update site for MY 2007-2009 S-Class and CL indicates that ver. 15.0, also covering 2015-2016 is the last release for NTG 3.0 systems; it is BQ 6 46 0340.
Personally, I find that infuriating. Ver. 14.0 was the only update for NTG 3.5 after the 2013 model was produced. Its road data dates from 2014, and it contains errors that were errors even when the discs came out (among other things I am constantly told to take an exit on I-275 in Tampa where none exists; they were detours during road construction). Cutting W221 and CL owners off after just one update is simply ridiculous, and will have me looking at other brands for my next car purchase.
"We can confirm that there will not be additional navigation updates for the NTG3.5.
One such solution was presented by member hilarushi at https://www.benzworld.org/forums/au...5-mirroring-iphone-android-phones-comand.html - it is a wireless solution using the phone as a wi-fi hot spot transmitting to a wi-fi rebroadcaster (such as Anycast) with an HDMI output that in turns feeds into a device that converts the HDMI output to analog RCA output (https://www.amazon.com/s/?url=searc...h=n:15684181&field-keywords=HDMI2AV+Converter), in turn feeding into the MMI aux inputs that can be selected and displayed on the COMAND screen. One would have to use that somewhat balky setup with a Video In Motion device (I would recommend the one by NAVIKS, having used one for a brief time). The setup can be used with either iPhone or Android.
A second method is wired; using an Apple Lightning to HDMI output cable (https://www.apple.com/shop/product/...cadc2c02fbd989c4e20d6a519f778df5c5f5782896ea6), one that then connects via an HDMI cabe to the same HDMI-to-analog device used in the wi-fi connection above. Selection of the RCA video is again made on the "Video" menu of COMAND. I do not know if iPhones having 30-pin output will work as well, but there are a number of HDMI adapters for various Apple devices. I have not explored similar cables for Android.
Both methods transmit audio together with the smart phone map display, so you can get turn-by-turn instructions. Neither method offers nav data on the multifunction display. Both methods involve a bundle of unsightly wires that would need to be hidden, and require a power source. Frankly, I would only use such a setup if I were traveling in an area I am totally unfamiliar with, and I'd be tempted to do it just using an iPad instead of using all that stuff.
How much would this cost MB! Most MB owners are long term and multi-car owners. I have owned 7 over the last 20 yrs. I guess it's Google Maps from here!
2012 S350 BlueTEC (2), 2005 S430, 2005 E320 CDI, 2009 E320 BlueTEC
Just fired off an email to MBUSA expressing concern over having the map updates to continue. If others would do the same, just maybe we might get another update. It only takes a minute or two...
2015 S550
Discussion Starter · #4 · (Edited)
I have as well, seubill - here is what I wrote, and anyone who wishes to copy or adapt the language, please do.
Your message in response to my query (Incident 180824-000015) said specifically:
Therefore, I provide comment.
In addition to NTG 3.5 (MY 2010-2013 S-Class and CL, BQ 6 46 0341, v.14.0, for calendar years 2015-2016) the MB nav map update site for MY 2007-2009 S-Class and CL indicates that v.15.0, BQ 6 46 0340, also covering calendar years 2015-2016 was the last release for NTG 3.0 systems.
I find that infuriating. V.14.0 was the ONLY update for NTG 3.5 after the 2013 model was produced. That decision cuts off updates after issuing only one post-production on those models; and the V.14.0 update contains road data from 2014, and is approaching five years old. Cutting W221 and CL owners off after just one update is something I view as a betrayal, and that decision, if not reversed, will have me looking at other brands for my next car purchase.
I note that for the ’05-’06 W220s, four post-production map updates were released covering dates through 2014, eight years after the last W220 was produced. Here, we get three years of additional coverage, via only ONE update. That is a sorry decision by Mercedes. The tight integration of the NTG 3.5 with the car’s other systems prevents head unit replacement as a viable option. While there are several ways to get smart phone navigation data displayed on the NTG 3.5 and 3.0 COMAND screens, those alternatives involve running wires all over the console, and to the glove compartment to feed in through the Multimedia interface. That’s a great luxury car image, Mercedes: To stay current in a relatively late-model Mercedes, run wires all over the place to feed data to the COMAND display.
No, thanks. Even a Chevy doesn’t require that. And I note that your 2018 S-Class offers three years of “complimentary updates valued at nearly $750” according to the site at MB | General Error | HERE - which, according to pricing for the NTG 3.5 updates, would cover three separate updates. That makes it even more difficult to understand terminating NTG 3.5 support with one update.
I understand that profitability is always a concern for any auto manufacturer. However, I point out that updated navigation data is already available; it is being used in newer COMAND systems, and HERE! Maps produces current discs not only for Mercedes but for many brands of cars. The software and firmware for NTG 3.0 and 3.5 is proprietary to Mercedes (or its head unit manufacturer) already. The difference in cost would be almost negligible, especially if you used a pre-order system to minimize excess production. I will point out that one of the disincentives for updating those systems, especially NTG 3.5, was predatory pricing by some dealerships. One dealer I used to do business with tried to sell me the disc set for $249, then charge me an hourly labor rate for installation that totaled another $250. $500 is way too much to charge for a nav map update, and owners know it. We like driving our cars, but we don’t like being taken for a ride.
Another Mercedes dealer I now take my car to for service charged $20 for the disc set, and $230 for the vehicle-unique code (licensing) and the installation. That is in line with what I have paid before for updates of my other Mercedes cars (I have been an owner of five since 2003), and is a much fairer price. It is also the pricing scheme the parts manager at the first dealership told me was applicable, before they tried to stiff me for $500.
It seems to me that by controlling the prices your dealers charge for map updates, profitability issues on the map update would be minimized — especially when you compare it to the cost of lost new car sales that will result from this policy.
As an alternative, Mercedes might consider offering a module for purchase that would permit retrofitting NTG 3.0 and 3.5 units with Apple CarPlay or Android Auto, without running visible wiring across the console. But cutting owners of cars using NTG 3.0 and 3.5, especially NTG 3.5 off at one post-production update is a very bad move that I encourage the decision makers at Mercedes to reconsider.
2015 S550
UPDATE: I received a courtesy call from a Mercedes Customer Care "Executive Referral Manager" three weeks ago; he said he would try to get a definitive answer to this issue and get back to me. No return call, despite my subsequent efforts to contact him.
UPDATE 9/28/2018 -: After a month of trying, I did receive an updated response from Mercedes Customer Assistance today:
"I have confirmed with our product specialists that there is not a new update out for the NTG 3.5 systems, and we do not have knowledge of when an update will be released.
"Should you need to contact us via email in the future, please visit the www.MBUSA.com Contact Us page."
While that is a disappointing outcome, it does not seem to foreclose the possibility that another release could occur in the future. I suggest that MY 2010-2013 W221 (S-Class) and 2009-2014 W216 (CL Class) owners make such contact, and let them know of your interest in an update.
2015 S550
Discussion Starter · #6 · (Edited)
UPDATE 10/2/2018
An Executive Referral Manager from MBUSA called today to confirm that there will be no further updates to the navigation maps for NTG 3.5; v.14.0 is the final release. Version 15.0 is also the final release for NTG 3.0.
The first post in this thread has been updated to provide some alternatives for current maps.
2015 S550
Discussion Starter · #11 · (Edited)
Thanks for responding. Yes, I was discussing the NavTool, because I have been interested in it as a product that would not require replacement of the OE system, but instead, supplement it. True, the NavTool retains the OE screen, which is not a touchscreen (and also does not pick up annoying fingerprints, as a touch screen does). Those of us who have the COMAND system are already familiar with operation of the controller knob, so that might be viewed as a plus. As to screen resolution, that could be a concern. How are you connecting your phone to the system? Do you use the device with the HDMI input (e.g., with a Lightning to HDMI adapter if it's an iPhone), or are you using some other method such as a wi-fi connection? If you have tried both, is there a difference?
Some of the other systems linked in the first post create a wi-fi hotspot to connect to the screen, which I would guess would not be particularly clear.
Regarding audio, do you mean that the OE audio system (or input) is no longer functional? If I understood the NavTool website's video properly, there was a way to disable the NavTool output and revert to the OE COMAND screen, using a button on the telephone keypad. Is that for video only? Do I understand correctly that if one installs the NavTool system that one is limited to whatever you have connected to it (e.g., a phone), and lose other audio sources such as radio or CDs? What is the model year of your car? The connections to audio differ between the '07-'09 and the '10-'13; my uneducated guess was that at least in '10-'13, connection to the MMI RCA jacks would still leave other MMI inputs selectable via COMAND.
Some of the other options shown in the first post would entirely replace the OE screen, but we haven't had much feedback on those either. We'd love to have some.
2006 CLS500
Audio system sounds fine...but using the phone does not sound good.
· Outstanding Contributor W221 Moderator
2015 S550, 2010 E350 P1/P2, 2002 ML320
I've had it since July, only one issue so far and that was a failed part replaced for free. The display is bright enough to see during a Phoenix day and automatically dims with the MB dash. I have Waze and Spotify loaded on it and have it connected via a T-Mobile SyncUp drive module to the Internet. One of my favorite things is that you can set it to automatically start navigation on startup. Then Waze checks the time of day and asks if you're heading home/work and finds the best route.
I installed it myself, using the information on the mbworld forum.
2007 SL55 AMG P030 -2007 S65 AMG
Mine arrived about a week ago I have been bogged down on fixing an unusual no start condition on a CL65 ( now fixed-bad DR-side SAM) so hopefully I'll find some time to tackle the install next week.
I appreciate your offer for assistance if needed.
Best H
Oh sorry, there's one thread that I made mental notes from:
MBWorld W221 Android discussion
Lots of interesting stuff to read in there, much of it doesn't apply now that these units are plug and play. Wound up purchasing this unit;
There are MANY to choose from but these guys had a good feedback profile and others on the MBWorld forum had used them. I had one issue with the video converter which just stopped working after a month. They sent me a new one and all is perfect now.
'07 GL320CDI
This isn't much of a problem for me.
A very nice German company called Kuda has a USA operation in Texas and provides phone mounts custom made for W221.
I suggest we think of our in-car navigation as being as obsolete as our cameras, i.e. replaced by our smartphone. The feature where once a "contact" is entered in the phone book, the phone instantly computes the GPS coordinates and can provide navigation prompts is something never available in our built-in systems anyway and data entry is so much easier on the phone in any event. If you must, you could likely get the audio prompt sounds through your car's speakers, although not likely in a mode that interrupts usual programming unless you're listening to music from your phone. (Maybe ... I'm too old to do this and only listen to Sirius.)
Anyway, most of my driving is rural and maps from 2015 still work just fine. It's fun to see the highways and occasionally see my progress toward a junction. There are very few brand new highways.
1 - 20 of 24 Posts
