Going through the forum, I understand the methods of replacing/flushing Brake Fluid are as follows:
1. At the Dealer/Indy on the Star DIAG wherein the SBC pump is made to operate through commands in the Star DIAG interface and to open the bleed nipples on each caliper as per instrcutions received form the DIAG while adding Brake Fluid to the master cylinder resevoiur. In short, the SBC pump is acting as a pressurised bleeding system.
2. To use a kit such as SpeediBleed where the "adaptor " is installed in place of the master cylinder resevoiur cap and Brake fluid under pressure (approx. 15psi) is added to it, while old fluid is drained through the open bleed nipples until "clean" fluid flows out. The pressure in this case is provided "externally" (from a hose that connects from the tire valve to the Speedibleed resevoiur.)
Both are pressurised methods of flushing. The difference being in the source of pressure.
Can someone please clarify my queries below:
1. I understand the first method above can only be done on vehicles with SBC as that is the pump that pressurises the system for bleed.
2. If the ignition is turned on (where all the dash lights are on, but enigne not started) and then a bleed nipple is opened, wouldn't that result in the pressure in the line dropping, hence activating the SBC pump , which would then attempt to increase pressure, but would result in the system bleeding.
If one was to continue to add fresh fluid to the resevouir until fresh fluid drained out the bleed nipple, you would get the system flushed.
Your opinions on the above please.
Thanks in advance.
Thanks in advance.
