722.6 CDI Shudder Droning RSN
82K views 50 replies 10 participants last post by  CanadianLex
#1 · (Edited)
Someone at another forum came up with a conclusion/solution. It has to do with the mapping inside the TCM controlling the TC lockup. I too feel it is a software issue that MB never wants to address. It is meant to improve fuel economy due to high pressure from peers. 2005-2006 E320 has a new TCM module called EGS52. However, it makes shifting very erratic.
Doktor A RSN Fix REVEALED!!!! - Sprinter-Forum
There is a fix for Sprinter CDI. Sprinter CDI is using 722.6 transmission as well. There is a very high chance that it can be applied to E320.
#4 ·
I had a problem with shudder on my w220 s320cdi 2003.
This seems to be a common problem with this age of car at about 100K miles.
I believe in around 2001 mercedes changed the lockup regime where it engaged in 3, 4 and 5 at low revs. I think in later models it locks in all forward gears.
This results in a faster wear in the clutch pack in the torque converter eventually causing a judder as you would get in a manual car with a worn clutch.
Also the valve body can wear aswell. The lubrication pressure valve bore wears resulting in poor lockup clutch pressure.
http://www.automaticchoice.com/Catalogue/m140-va30.pdf
I have changed my torque converter and had the valve body rebored and it has made it much better. There is still a slight increased vibration when the lockup engages but that is to be expected as the damping affect of the the fluid coupling is lost.
Before I carried out this work I tried cleaning the valve body and replacing the lockup solenoid (quite straight forward) but it made no difference.
One other thing to check for is glycol in the ATF as this can give similar symptoms.
Adam
#7 ·
Nice. I have read that people often report replacing the valve body fixes the juddering TCC lock up problem. I am thinking changing the TCC PWM solenoid valve will be worth to try as a cheaper fix 1st. All new valve body will get the new solenoid valves. I think one should also clean the screening shield on the TCC lock up passage too. Also, I think the speed/rpm sensors should be inspected for damage.
#8 ·
How much is that solenoid valve and how hard is it to replace it? I have exact same problems like everyone else. When car is cold there is lots of bucking, juddering and what not...once the car warms up shifting is almost perfect. Tried replacing ATF (complete flush), didn't really help that much.
Why don't you try Doktor A's (or whatever) fix? It's just $50
#9 ·
the solenoid is only around 35 dollars or so. DARF fix is more for people having permanent Rumble Strip Noise problem. I think our problem or at least my problem are that the TCC lock-up and release are delayed especially when cold. There is around 1 second delay I can feel it. More noticeable when you put the tranny in Gear 2, gas and let off the gas pedal. Tachometer will drop to 700 rpm and then you feel the TCC release. I am suspecting the PWM solenoid is acting up. Remember that it is NOT just an on off switch. Its extension or contraction are depending on some PWM signals. My feeling tells me that it is very prone to missing accuracy over time.
Now back to steps in changing the valve out. The valve is on the top side of the valve body covering by 1 plastic shield. The tranny pan will need to be dropped and wiring connector will need to be turned and unplugged. I think there the work is too hard except jacking up the car and getting under it. The pan is almost in the center of the car.
Again, DARF will require some hole drilling which I really don't feel too comfortable to do.
#13 ·
Thesis: PWM Solenoid OHM increases as temperate goes up. TCU does its adaptation only when temperate is up at operational temperature. Solenoid OHM increases as it ages with respect to temperature as well. TCU adjusts itself accordingly. However, the adjustment parameter is not suitable in cold temperature. ie, TCU applies too much duty cycle to the PWM solenoid when cold.
This is theory to be proven. However, i am not capable of using a data logger to plug into the TCC PWM solenoid circuit.
#36 ·
I did the DARF on a 2004 Sprinter 10K miles ago, and no issues, worked great, no more Rumble Strip. If you drilled the hole in the correct location and proper size, the issue must be something else like not enough fluid, or the valve body was not reinstalled properly or the wire loom connector seal allowing oil into the electrical area which can cause strange things...
#21 ·
Quote from sprinter forum: "Some vehicles will allow control of RSN with an orifice size as small as 0.0465"(1.18mm), others may require a larger 0.055" orifice. But the 0.052" orifice seems to work for most, without penalty of excess fuel consumption."
pelletman, sorry to hear that. How big of a hole did you make? I think I will replace the solenoid 1st b4 speculating on the DARF fix. How are you plugging the hole? I think some JB steel putty will do the job. Just make sure it can tolerate the temperate in the fluid.
#24 ·
TCC PWM Solenoid
Getriebe problem im kalten zustand : Mercedes E-Klasse W211
Here is another posting regarding the valve replacement fixes the jolting. So far, I have notice around 5 people online fixes their problems. I am going to order my parts very soon and pick it up near the US border. I know I should put my talk into action. However, It is cold and wet here in BC. It makes it very undesirable to work under the car with just jack stands.
#26 ·
I have read that article. W211 has a different TC than a W204. A2112501402 is the one being used. So far, I haven't heard of any stalling b/c of the TC in any W211. The testing routine that the article performed is no way any customer would pay out of pocket. The labor probably costs more than the parts itself. One might be better off to replace the whole TC and VB.
