Photo DIY: ABC Fluid Maintenance
173K views 72 replies 34 participants last post by  mrflex
How do you change the ABC and PS (power steering) oil/filters then? Would you just suck it out and pour in the new oil? Are there drain plugs for either ABC and/or PS? How about the filter part numbers for both? Where are they located PLEASE?
I know there are lots of questions as I am a dummy as it come to DIYs (but I would love to learn). Thank you very much in advance folks.
Sorry but this doesn't make sense to me. If I flush the oil and place the return line in the waste bucket, then no "used" oil will get back to the system. Why do I need to filter the waste oil?
I am not commenting about the rodeo but the procedure for flushing the ABC seems contradict with what I have been told. When/if I actually do it, I shall see :).
I understood that the filter is connected to the return line; that way, stuff will be filtered before it gets back to the system again. When you flush the system, you would put the return line in the waste bucket/container, and add oil to the reservoir until the return hose come back with clean oil.
I will keep in mind both methods and see which one is right LOL
