Originally Posted by lnguyenh Sorry but this doesn't make sense to me. If I flush the oil and place the return line in the waste bucket, then no "used" oil will get back to the system. Why do I need to filter the waste oil? |
I am referring to a flush of the entire system. Ivanj always takes a "systems engineering" approach, my friend.
(PM me for more experiences with ABC.)
You don't need to filter the waste oil per se since it will be recycled.
The existing filters are already compromised. The return oil goes through the new filters that catch the junk before they hit the pumps $$$$$ and valves.
Then you put in new filters for low $ and renew the oil $$$$.
The flush system you use maybe different - avoiding the new filters - but the MB techs were referring to the systems used by some MB dealers who made the investment.
The "retired" MB techs also said it is best to run the flush at the lower end of the pressures recommended. They said they have seen high pressure "quick and cheerful" flushes blow out the ABC valves and pumps - you don't want that $$$$.
After the service you might want to ask the dealer to put the ABC car through the "rodeo test." It is a necessary but not sufficient test to catch other problems (ABC pumps, for example.)
Hope this helps. Did I answer your question?
