If you have followed my other posts you know I have been getting this code. I have thought it was tied to timing issues.
The code is for the right bank (passenger side) exhaust cam position sensor. After turning the crank to 305 degrees and pulling the cam position sensors, I determined the I needed to look closer.
All except the right bank exhaust pulse wheel look good. So, I pulled the right front timing cover off and the exhaust gear was on tooth off. Placing everything back together. Everything looks good.
Ok, It looks good to me.
However, I am still getting the error.
Bad sensor? Bad wiring?
Any suggestions?
Any suggestions?
